Eevee Cryptomatte Render Pass with Hair Particle Glitch #89967
Reference: blender/blender#89967
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 30.0.100.9684
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Worked: I have not tested this in previous 2.9 versions so I don't know whether it was a bug or not. However, this glitch only happens in Eevee; everything works as intended in Cycles.
Cryptomatte pass may completely ignore objects depending on whether a "chosen" object has hair particles.
Basically, Blender Eevee will "choose" an object. Based on two different Blender files that I have tested, the "chosen" object is the first mesh object created in the scene. In my scene and snapshots below, the cube was the first created object so it is the "chosen" object.
If no objects contain hair then there are no issues with Cryptomatte:
(This snapshot is the result of the CryptoObject00 of the Render Layers being plugged directly into the Composite node)
If however an object contains hair particles (whether the object is visible to the camera or not doesn't matter) and the "chosen" object does not have hair particles, all objects will become invisible in the Cryptomatte pass except for the "chosen" object.
(In this snapshot, I have added hair to only the sphere. Although the cylinder does not have hair, it still turns invisible in the Render pass)
But if the "chosen" object has hair, no objects will be affected by the glitch whether or not they have hair:
There is no bug in cycles. Here is the same scene in Cycles. It works completely fine:
Blender crashes when I try to reproduce this error on the default Blender scene with all my Preferences set on default, so I have attached a very simple Blender scene that contains the issue on my end. When you hit the Render button you should see a render that looks like the 2nd image on this post (the cube is visible but the hairy sphere and normal cylinder are completely invisible).
This glitch may have to do with a specific Graphics card, because I tested this scene on my brother's Windows 10 computer and there is no glitch.
Here is the Blender scene:
CryptomatteEeveeBug.blend
Added subscriber: @DreamNoms
Added subscriber: @iss
Can't reproduce here on Radeon RX550/550 too, so it is probably issue with your GPU.
Can not reproduce either with 2.92/2.93LTS
@DreamNoms , driver version (
27.20.100.8681
) is little old than the present version:30.0.100.9684
Can you please try again after upgrading the driver: https://downloadcenter.intel.com/product/126789/Intel-UHD-Graphics-620
I have updated my driver. The glitch is still present with an updated driver:
Thanks for checking. Does this happen with fresh builds? (https://builder.blender.org/download/daily)
Can you please add system info file generated from the help menu (
Help -> Save System Info
)?any news?
Please add the file.
