Regression: Strange crease when using proportional editing with the "connected only" option turned on (edge selected) #89968
7 Participants
Reference: blender/blender#89968
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.72
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
Pretty sure this is caused by
21b9231d7f
When using proportional editing, there is a strange pinching/creasing that is going on where it should be smooth. It seems to only happen when "Connected Only," is turned on
Test File:
#89968.blend
Added subscriber: @ZachHixson
#102031 was marked as duplicate of this issue
Can confirm. Not sure if this is known issue or reported before. Will check before confirming.
Added subscriber: @iss
Can you provide sample file that demonstrates this issue well?
Hi @iss , added the file. Don't see the similar issue reported before.
@iss , can you also reproduce?
I can reproduce, but only in 2.93 not in 3.0 so this seems to be fixed already, can you check that?
Created the file with 3.0.0 itself so yes I can reproduce (
118803893e
)Also checked with debug build (
ff01070b5c
)Added subscribers: @brecht, @lichtwerk
21b9231d7f
.It works well (even in this example) if a single vertex is selected.
Can confirm it gets bit wonky if a region is selected though.
From the D10068: Transform: approximate geodesic distances for proportional edit connected mode:
@brecht:
?Strange crease when using proportional editing with the "connected only," option turned onto Strange crease when using proportional editing with the "connected only," option turned on (region selected)Added subscriber: @mano-wii
This indeed seems to be a limitation in the algorithm that estimates the geodesic distance of the vertices. (seen in
geodesic_distance_propagate_across_triangle
).If I understand the code correctly, when the sum of the two geodesic distances of the triangle's reference vertices is less than the distance between these vertices, a fallback distance is returned, (which in this case coincidentally is the real distance).
But when the sum of the distances is greater than the distance between the vertices, the computed distance is equivalent to the one shown in the image below, which is smaller than the fallback, and so the propagation is done differently.
Perhaps it would be possible to improve this by indicating a direction vector for each vertices.
Or compute a different value when the geodetic distance is smaller than the one between the vertices?
Anyway, it doesn't seem like a trivial change.
The code includes propagation across edges also, not just across triangles.
There may be some more complex cases where it's harder, but at least in this simple case it should be able to find accurate distances that way.
It's also a regression compared to earlier Blender versions, which was not known.
Strange crease when using proportional editing with the "connected only," option turned on (region selected)to Regression: Strange crease when using proportional editing with the "connected only" option turned on (edge selected)Added subscriber: @Twixuss
