Blender crashes when applying SSS shader to material (Rendered) #90004
2 Participants
Reference: blender/blender#90004
Operating system / Graphics card
Win 10 64-Bit / RX 5700xt
Broken: 2.93.1
Worked: N/A (Have only been using blender since 2.93)
Render Engine: Cycles
(Rendered Viewport) Increasing subsurface value in Material properties on an object causes computer to hang.
(Rendering Image) When trying to render an image (with the previous information) no image will be rendered and AMD Bug report tab will appear.
On an object, go to the material properties pane, add a material and change the "Subsurface" value to anything along the scale. Only occurs during rendered viewport or trying to render an image.
Test File:
Donut.blend
Added subscriber: @BuffaloMozzarella
Can not reproduce with the default startup file. Does this happen with specific file?
Can you please attach the simple .blend file?
Donut.blend
Some extra Information: Just did a little bit of testing on the start up and found that when I added SSS to the default cube it did not cause a crash. Moved it above origin, still no crash. But then as soon as I added a plane beneath it caused the same crash. Hope this can help.
Thank you for the file. Still no crash here. Does this happen with both GPU and CPU device?
Still steps to recreate the crash are unclear to me. Can you please mention the exact steps? or a short video will also be useful
Also, please attach the crash logs: https://docs.blender.org/manual/en/latest/troubleshooting/crash.html#windows
2021-07-21 20-18-20.mp4
Thank you for all your help so far. Here's a video of the problem.
Thanks for the video. May be the issue is with your GPU. Does the issue start happening after recent changes in Driver settings or updates?
Can you check again after upgrading the driver to the recent version: https://docs.blender.org/manual/en/latest/troubleshooting/gpu/windows/amd.html
Please attach the system info generated from Help menu:
Open Blender -> Help -> Save System Info
).Also, I can not reproduce on my system
So I found a way to get the SSS to work again without causing graphics to break. I re-installed an older version of Radeon Software (21.5.2).
I also tried the optional build of the driver (21.7.1).
I've added my System-Info here incase you still would like to take a look at it.
system-info.txt
Thanks for checking. Can I consider the issue is fixed at your end?
Yep! Thanks for all of your help.
Changed status from 'Needs User Info' to: 'Resolved'
Will close then. Thanks again for the report :)
Feel free to reopen the report or submit a new report if problem reappears
Some new findings. Re-updated to most recent version of AMD Software and found that Branched path tracing also caused the problem. Once changed to standard path tracing issue no longer occured.
@BuffaloMozzarella , can you please create a separate report for it?
Separate report is useful I guess if steps are different to recreate the crash.
Also add crash logs in the new report: https://docs.blender.org/manual/en/latest/troubleshooting/crash.html
I went through the steps to try and find a crash log but can not find it anywhere, I think it causes a hang but doesn't actually crash blender.
Will make a seperate Report for it though. Do I just post and set as resolved?
Just report the issue. Triagers, developers will check the report and decide the status :)
