frame change handlers stop getting triggered after rendering more than 3 to 5 times. #90032
Reference: blender/blender#90032
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.93.2 Release Candidate, branch: master, commit date: 2021-07-07 05:52, hash:
9e64fd461a
open file and follow instructions in the script editor:
frame change handler only works intermittently when called from code.blend
Added subscriber: @3di
This comment was removed by @3di
Added subscriber: @ideasman42
Testing in 2.93 release & master, the second render is always raising an exception:
KeyError: 'bpy_struct[key]: key "file_out_keep" not found'
The second execution sets the the frame, this runs the frame-change handler twice, the second time it runs it can't access the key.
@3di can you confirm if this is the behavior you see too?
Changed status from 'Confirmed' to: 'Needs User Info'
you shouldn't be getting that, that's a remnant of an old addon. Delete the 'file_out_keep' scene property to resolve that.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Tested again with 2.93 release and I'm not getting this anymore.
I've looked into the Python code and to me it seems it relies on a specific order and way which and in which order the handlers are run.
The frame-change handler might run prior to render, and it might not be run after the render. This makes the state machine of using
finished rendering
very fragile.What happens now is that at the end of the first render
finished rendering
is created and then theupdate_on_frame_change
is called. Next time you render, the render pipeline calls the frame change handler, which "sees" that thefinished rendering
property exists and will do things which I believe intention is to only do at the end of the render. Note that theupdate_on_frame_change
is also called afterpre_render_job
during the first render, so there is no descrepency in the which handlers are called.I've tried ti simplify the code to make it more visible, hopefully without affecting the overall state machine.
I believe there are more straightforward and robust ways of achieving your goals, but looking into those is outside of a bug fixing process. You are welcome to join and ask for advices in the
#python
room on the blender.chat.
