Where to put "Mark as Asset" #90045
Reference: blender/blender#90045
Do we want it to be just in the Outliner and in the material slots context menu? Users seem to expect it in the 3D View context menu. If we add this we should probably also add it to all kinds of context menus in other editors.
Added subscriber: @antoniov
In Grease Pencil I have added in Context menu, but it's different because only can work in Edit Mode for a group of strokes.
EDIT: Really, in GP is "Create Asset" because you are not "marking"...you are adding a new asset base on part of the existing data. I have also an option to create several assets at time with the same data (Create Asset for All Layers in separated Assets)
Added subscriber: @AndresStephens
Suggested expected UX per editor, which can be divided into two levels of UX, the intuitive and the granular:
The intuitive UX:
3D View to/From Asset Browswer
Outliner to/From Asset Browser
From/To Property Editer, material example
From/ NLA
TLDR, basically, if something exists anywhere, you can somehow drag it (and/or hold a key modifier) to the browser and it will add and show immediately.
The granular UX:
The current UX issues
Current functionality:
For 3D View editor, there is no method to mark assets. From the Property Editor it's not consistent nor clear to mark assets presented in the Property Editor (though you can). From the node editor there is no GUI that implicates that the node group could be marked, or that a material could be marked (unless you already know of the icon right click method)
For the Node Editors, you can't mark assets in the canvas, in the 3D View, you can't mark from the canvas. From the material editor, there is no method to mark the materials or nodegroups from the canvas unless you go to the outliner, a disconnect editor from the file browser.
Also, you can't even use the Asset Browser to mark assets to itself....
Ultimately the UX has no intuitive system where you can just use any editor that manages data blocks (all editors) to then directly click or drag on any data block (object, VSE strip, group nodes, collections, textures, image nodes, mesh data, mesh material in a slot, etc) to then move or add it to the library.
The current UX is this:
It should be this:
It saves 20% of the workflow and is more discoverable intuitively, and with optional granularity from the outliner.
UX Goals
1. Efficient Access in the GUI from everywhere where relevant: A mouse action with least amount of zigzag and clicks to add the asset (1 click directly on asset in any editor, open menu, 1 straight line to entry, 1 click to confirmt; or ALT/SHIFT/CTRL + 1 MBpress on asset, drag to browser in 1 straight light, release to confirm)
2. Visual feedback: when the asset is marked into the browser it should flash the user, so they don't have to review all the time, a notice or popup, an icon jiggle or highlight on the recently added item, or jump and/or highlight to item when added.
3. Discoverability: randomly clicking to get and context aware menu on data blocks in all editors anywhere should allow to make the connection to the asset browser, or allow to intuitively move them from the GUI to the Browser without needing to discover the floating menu.
4. Consistency Make sure that regardless of the asset and it's representation, that the method to add them are all very similar.
5. Optional Granularity If the asset is an object that also contains mesh data, is in a parent collection, or has materials - the option should be able to allow the user to choose what to mark from the top level, or to just mark all, or mark as an entire collection - with a little wizard (Repeat Last Menu) dialogue.
Drag and Drop always is intuitive. But if we can't get cross-editor dragging and dropping to mark, then having some top level access (contextual add button in editor header to add what is active selected from any editor the button is used - and optionally set by hotkey) or a single level context menu contextually sensitive to any datablock anywhere will help. For the 3D View, which has top level items like instanced collections, objects that contain modifier stacks, mesh data, materials and textures in materials - this would need some kind of context aware granular control.
Alternative granular and intuitive system: keep the marking UX all in one editor.
The blender file view of the Outliner (where you mark from) could also be shown in the Asset Browser "Current File" view, listing all potential data blocks for the library, and a toggle can show/hide "All Datablocks" where you can then highlight and tag whatever you want in one click.
This will minimize the multi-editor workflow to use the asset browser and disconnect between all editors - and there wouldn't need to have hard engineering to be able to drag datablocks across editors and re-map how the right click context menu would work in all the editors and method to right click on data blocks - which could be a consistency nightmare.
This will also keep the workflow consistent with understanding how datablock management works without needing to make a connection between two unique editors. The outliner is not the asset browser, it should NOT be the go to for the Asset Browser UX, which is disconnect - unless you want granularity like the Blender File view.
Other alternatives:
OR you can provide all systems to hit the UX targets: Context Menus in all editors with data (not just outliner), Drag and Drop from any editor/list, and "Show All Data Blocks to mark from Asset Browser".
AND/OR you can make the selected data block context before adding, a GUI system within the Property Shelves panel that will update to active/selected and generate thumbnail and asset browser information so then (no matter the editor) the user can see what they can optionally and contextually add without needing the browser open or focus in outliner - relevant in animation editors, node editors and 3D View - like a "highlight current" + "fill info in the panel" + "Optionally mark what is selected with the properties?" type of UX. So the contextual GUI wizard is top level relevant to the editor.
Select a node group in the Node Editor
The tab and panel for the asset browser add panel highlights the nodegroup.
Fill in details: It can assign custom thumbnail, tags, description
Press a button "Mark as Asset" in the panel. This will add selected nodegroup to the browser from the panel, and the button could optionally be a hotkey. This panel updates based on selection.
Select object in 3D View editor
The tab and panel for the asset browser add panel highlights the object.
Fill in details: It can assign custom thumbnail or press button to refresh, add tags, description
You can toggle if it's top level (add as collection), or lower level (add textures, materials, mesh data).
Press a button "Mark as Asset" in the panel. This will add selected 3D asset to the browser from the panel, and the button could optionally be a hotkey. This panel updates based on selection (stored datablock info).
Select material in Node Editor (any other node that isn't a data block, ei Node Group, Image Texture)
The tab and panel for the asset browser add panel highlights the material.
Fill in details: It can assign custom thumbnail, tags, description, generate custom thumbnail
Summery
Basically, make it intuitive and still maintain granularity. Make it top-level discoverable and easy to use (mouse clicks anywhere on a datablock, etc). Try keep it in the editors or where data blocks are relevant, don't sectorize it only to Outliner.
