Wrong undo/redo sequence with direct transform change (via Item/transform panel or addon) #90234
7 Participants
Reference: blender/blender#90234
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 375.70
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
1b8d33b18c
Undo operation is not working properly with
Copy attributes addon
.[refer the video to understand the situation better]
Exact steps to Reproduce the error
2021-07-28_13-59-32.mp4
To reproduce
Exact steps to Reproduce the error (Addon Case)
Copy Locations
[Notice that the undo operation ignores all the steps from edit mode and directly switches the mesh to the initial position]
2021-07-27_13-33-38.mp4
Test File:
#90234.blend
Added subscriber: @Vyach
Added subscriber: @APEC
I can confirm with 3.0.0 (
6ee14c966d
)Added subscriber: @mont29
Changed status from 'Confirmed' to: 'Needs User Info'
@PratikPB2123 The task as it is is not acceptable.
If you took the time to watch the video and actually understand what is going on, then please edit the report and add usual expected info (clear description of the issue, steps to reproduce, etc.)
Also, if this is only reproducible with an add-on, and not 'vanilla' Blender, then it is most likely an add-on issue, please do not add core and such tags to it then.
Hi @mont29 . Issue only happens with
Copy attribute addon
.The problem is related to Undo operation so I added the #core module. (my apologies if I did the mistake)
Thought video itself is enough to describe the problem. Ok, I will edit the report.
Okay, I tested with sculpt mode.
As I thought bug is not related to addon. For some reason object mode actions and edit/sculpt mode actions loose proper order in undo sequence.
To reproduce
0. Make sphere, go to sculpt mode.
@PratikPB2123 thanks for editing, not much time to do it…
Added subscriber: @lichtwerk
Any news? Looks like a bug to me.
@lichtwerk , can you please check this?
Wrong undo/redo sequence with Copy attributes addonto Wrong undo/redo sequence with direct transform change (via Item/transform panel or addon)Added subscriber: @Garek
Can reproduce with 2.92, 2.80 and 2.79b.
Test that I made:
Properties
panelIncorrect undo-redo.avi
Expected behavior on step 8: reverse steps in order 7, 6, 5, 4, 3, 2.
Factual behavior on step 8: reverse steps 7, 5 (strokes), then steps 6-4-3 (object properties via
Properties
panel and change to sculpt mode) all at the same time, then step 2.Expected behavior on step 9 (taking into account wrong behavior in step 8): redo step 2, then steps 3-4-6 (object properties via
Properties
panel and change to sculpt mode) all at the same time, then steps 5, 7.Factual behavior on step 9: redo step 2, 3, 5, 7 (steps 4, 6 lost completely).
Added subscriber: @Imaginer
