Rendering > Shader Nodes > Input > Value Node - Grammar #90399
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#90399
Pagename:
render/shader_nodes/input/value
Blender Version:
2.93
Documentation Language:
en
Permanent link
"In the example below the Value Node is used to control multiple values at once, this make"
should be:
"In the example below the Value Node is used to control multiple values at once, this makes"
Added subscriber: @Denis_NICOLAS
This issue was referenced by 8273
