Constraint validity not updated with library overrides #90570
5 Participants
Reference: blender/blender#90570
2.93.2
The validity of a bone constraint is not updated on file loading when using library overrides
Download these two files to the same folder
invalid_constraint_01.blend
The first file only contains an armature with two bones in it, the bone on the top has an invalid constraint in it.
invalid_constraint_02.blend
In the second file, the armature is linked from the first file and the subtarget value of the constraint has been modified with a library override to make the constraint valid again.
After saving the second file and reloading it, the constraint appears to be invalid.
The constraint needs to be disabled and enabled again each time the file is loaded to make the constraint behave properly.
Added subscriber: @AquaticNightmare
#87898 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Can confirm.
Added subscriber: @IsiacDaGraca
I also have this problem repeatedly, makes loading a project take much longer cause I need to find all the missing constraints between linked characters. Forcing a refresh of every single constraint not already included with the linked group.
Shouldn't this be fixed as a bug in the LTS?
Added subscriber: @mont29
Note that the change required to fix this is fairly important (in term of code behavior changes), so the fix will definitely not be backported to 2.93LTS. Way too risky.
This issue was referenced by
43167a2c25
Added subscriber: @zanqdo
