ALT Q Pie Menu Shortcut Deprecated, when not in object Mode #90727
Open
opened 2021-08-17 11:23:15 +02:00 by Franklyn Afeso · 14 comments
Graphics card: Intel(R) UHD Graphics Intel 4.5.0 - Build 27.20.100.8681
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-16 16:57, hash: blender/blender@4dba206011
Worked: 2.93
The ALT + Q View Pie menu only works in object mode, reason being the shortcut is now used for mode transfer between multiple objects
  • Enable 3D Viewport Pie Menus addon
  • In object mode press {key Alt Q} (Will display pie menu)
  • Preform same step in other object interaction mode (eg. edit mode)
This wouldn't be much of a problem, but since there isn't anyway to change the keymaps to call the pie menu, it means having to switch to object mode to use that functionality.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: Intel(R) UHD Graphics Intel 4.5.0 - Build 27.20.100.8681 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-16 16:57, hash: `blender/blender@4dba206011` Worked: 2.93 **Short description of error** The ALT + Q View Pie menu only works in object mode, reason being the shortcut is now used for mode transfer between multiple objects **Exact steps for others to reproduce the error** - Enable `3D Viewport Pie Menus` addon - In object mode press {key Alt Q} (Will display pie menu) - Preform same step in other object interaction mode (eg. edit mode) This wouldn't be much of a problem, but since there isn't anyway to change the keymaps to call the pie menu, it means having to switch to object mode to use that functionality.
Author
Added subscriber: @afeso
#100380 was marked as duplicate of this issue
#98669 was marked as duplicate of this issue
#94940 was marked as duplicate of this issue
#94325 was marked as duplicate of this issue
#94087 was marked as duplicate of this issue
Member
Member
Added subscriber: @volliwood
Member
Added subscriber: @HONGSUNGWOO
Member
Added subscribers: @rafaeltas, @Garek, @BrendonMurphy
Member
Added subscriber: @faqart
Member
Added subscribers: @JonathanUmana, @OmarEmaraDev
Member
Added subscriber: @pawsumn
Reference: blender/blender-addons#90727
