Knife Project not working #91139
Closed
opened 2021-09-02 20:02:15 +02:00 by Adel Haiba · 30 comments
Graphics card: Radeon(TM) RX 460 Graphics ATI Technologies Inc. 4.5.14736 Core Profile Context 20.9.2 27.20.12031.1000
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash: blender/blender@b7205031ce
Knife project not working, gives an unexpected error
I added a cube subdivided it twice, then added a circle for a knife project from the top, then selected the circle first, then the cube, entered the edit mode, and selected knife project from the mesh menu, and produced unexpected error.
"No other selected objects have wire or boundary edges to use for projection"
knife_project_error.blend
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: Radeon(TM) RX 460 Graphics ATI Technologies Inc. 4.5.14736 Core Profile Context 20.9.2 27.20.12031.1000 **Blender Version** Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash: `blender/blender@b7205031ce` Worked: (newest version of Blender that worked as expected) **Short description of error** Knife project not working, gives an unexpected error **Exact steps for others to reproduce the error** I added a cube subdivided it twice, then added a circle for a knife project from the top, then selected the circle first, then the cube, entered the edit mode, and selected knife project from the mesh menu, and produced unexpected error. "No other selected objects have wire or boundary edges to use for projection" [knife_project_error.blend](https://archive.blender.org/developer/F10363808/knife_project_error.blend)
Author
Added subscriber: @Adel-Haiba
blender/blender#91723 was marked as duplicate of this issue
blender/blender#91483 was marked as duplicate of this issue
blender/blender#91309 was marked as duplicate of this issue
blender/blender#91283 was marked as duplicate of this issue
blender/blender#91147 was marked as duplicate of this issue
Member
Added subscriber: @FloridaJo
Philipp Oeser was assigned by Joel Godin 2021-09-03 03:41:45 +02:00
lol, I just did the same thing today.
They changed how it works.
Needs to be merged with #90656
lol, I just did the same thing today. They changed how it works. Needs to be merged with #90656
Author
Hello, the manual still says, is to select both objects in the object mode and then enter the edit mode?, show me how is the new way then?
Member
Changed status from 'Resolved' to: 'Needs Triage'
Member
Not sure if change expected in blender-v2.93-release branch. Also manual is not updated yet if the present behavior is expected for 2.93.4. (So reopening the report)
Not sure if change expected in `blender-v2.93-release` branch. Also manual is not updated yet if the present behavior is expected for 2.93.4. (So reopening the report)
Member
Added subscriber: @Yiyang-Li
Member
Member
This is not bug, functionality works as intended. Only manual part requires an update.
(asked Campbell Barton: change is expected in 2.93.4)
This is not bug, functionality works as intended. Only manual part requires an update. (asked Campbell Barton: change is expected in 2.93.4)
Author
Ok, so I can use only curves and text for knife project?, I can't use mesh circle like before for the knife projection anymore?
Philipp Oeser removed their assignment 2021-09-06 09:03:13 +02:00
Member
Added subscriber: @lichtwerk
No, you still can use a mesh.
I did a video on it, just I said Shift + Select in the video, should be Ctrl + Select.
https://youtu.be/M9EMWYOgmqk
> In #91139#1215844, @Adel-Haiba wrote: > Ok, so I can use only curves and text for knife project?, I can't use mesh circle like before for the knife projection anymore? No, you still can use a mesh. I did a video on it, just I said Shift + Select in the video, should be Ctrl + Select. https://youtu.be/M9EMWYOgmqk
Member
Added subscriber: @sse
Member
Added subscriber: @Blendify
Member
Hi @Blendify , can you please make this change for 2.93 manual: rBM8325 ?
Member
Added subscriber: @GAPsWorld
So now i know the correct way to do this, i can confirm it works, not sure its necessarily a better way, but thanks! :O)
Member
Aaron Carlisle self-assigned this 2021-09-12 21:03:39 +02:00
Member
The documentation fixes made in the 3.0 manual have been backported to the 2.93 manual.
The website should be updated within the next 90 minutes.
The documentation fixes made in the 3.0 manual have been backported to the 2.93 manual. The website should be updated within the next 90 minutes.
Member
Added subscriber: @EricBu
Member
Added subscriber: @JohnSinyard
Added subscriber: @JosberthArellano
This is still unliveded in Version 2.93.3 It worked, after that version of 2.93.4 onwards that error appears.
8 Participants
Reference: blender/blender-manual#91139
