Crash when setting asset preview image from python (ASAN heap-use-after-free in render_preview.c) #91197
5 Participants
Reference: blender/blender#91197
Graphics card: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.47
Broken: version: 3.0.0 Alpha, branch: master (modified), commit date: 2021-09-02 14:26, hash:
6fc92b296f
This is an intermittent crash when running the script in the text editor. Happens after a programmatic render, setting object as asset and assigning an image file to that asset.
It may work and mark the cube as an asset and assign it a preview, OR it may crash Blender.
Sometimes it happens on the first run, other times, it takes several runs (5-10) on different cubes that have not yet been marked as assets.
Other times, I've had to duplicate the pile of cubes and select a new one and re-run the script.
[Simplified ASAN repro]
#91197-simplified.blend
[Previous Crashing File and ASAN report]
#91197-crash.blend
#91197-asan.txt
[Original Data below]
crash.blend
**Stack Track From Crash
Added subscriber: @guitargeek
Python Script Crashes Blender - May be related to Setting Asset Preview Imageto Crash when setting asset preview image from python (ASAN heap-use-after-free in render_preview.c)Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @deadpin
I updated the crash.blend file above since it wouldn't run by itself. It was still trying to access your
scene.asset_snapshot
variable.In any case, I can reproduce the crash the first time with ASAN. It almost looks like the default preview image job (triggered asynchronously by
asset_mark
) is overlapping with the custom preview image operation.I attached the full ASAN report above.
The current version of the script does not crash because I removed the need to switch editor types:
https://github.com/johnnygizmo/asset_snapshot
Added subscriber: @dr.sybren
Changed status from 'Confirmed' to: 'Needs User Info'
Please take some time to minimize the script, so that every line that is there is actually required to reproduce the crash. That'll help a lot in figuring out what's going wrong.
Modified the description to include a further simplified repro (
) as I'm still getting ASAN failures here. The issue is primarily because of the interaction betweenasset_mark
andlib_id_load_custom_preview
trampling over each other.The
asset_mark
api is very precarious. It starts an async icon preview job for which the python caller has no way of waiting or knowing when it finishes.But even if you try to somehow "wait", (by sleeping) in the python script, this still fails due to how the single-thread python execution happens. The "end" of the icon_preview job is not permitted to run while the python script is executing it looks like.
This will probably be a common pattern to do in general. Script authors will want to automate the marking and setting of custom preview image for their users.
This is good feedback, thanks.
Idea to fix this issue is to add a
render_preview:bool = True
parameter to theID.asset_mark
function.When set to False the preview render will not be performed.
This issue was referenced by
1c5722ba07
Since Jeroen's comment the ideas changed a bit. Instead of passing a boolean, the two operations performed by that
ID.asset_mark()
function have been separated.ID.asset_mark()
now only marks a datablock as asset, and ``ID.asset_generate_preview()` should be called to actually generate the previews.
