internal error: modal gizmo-map handler has invalid area #91360
Reference: blender/blender#91360
Graphics card: GeForce GTX 950M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.40
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-11 20:00, hash:
15405685d9
When rendering to the Image Editor and toggling "maximize area" while rendering, an error is displayed in the console
Step to Reproduce
test.blend
Preferences
>Interface
>Editors
>Temporary Editors
>Render In
is set toImage Editor
test.blend
userpref.blend
Added subscriber: @cheteron
Thanks for the report. Can not reproduce on master:
b5a1c194c5dde20b13e3dd3372055d8b5e58a18e
Did you try with factory settings?
File -> Defaults -> Load Factory settings
What steps exactly you have followed? Can you please clarify?
From present info, I guessed these steps:
View -> Area -> Toggle Maximize Area
With my settings
test.blend
userpref.blend
M3EzBRDqUx.mp4
With default settings
Then reverse settings to saved
Disable textools and tissue
Hi, I am not able to reproduce with default settings (neither with you preferences)
Reproducing steps are still not clear to me. After opening the file what exactly I have to do? (Just hitting render does not cause the issue)
Try with my settings. Just hit render, only when rendering hit ctrl+space (maximize area) in render view, then error will appear in console.
I have not seen this with the default settings, but I cannot work with the default settings, because a lot of hotkeys are tied, and the interface has been reconfigured. Otherwise, what's the point in personal settings if the blender only works on default
Hi, still unable to reproduce with provided
userpref.blend
file. May be some add-on is interfering?Could you try enabling one add-on at a time and see when the error occurs?
I think an external add-on introduces this issue because with rest active (official-community) add-ons from your
userprefs.blend
, described issue is not reproducible.I turned off all "User" addons, and same problem. Reinstall new Tissue - same problem. Turn off Tissue - same problem. I tried to disable the settings of each category, even recovering hotkeys - the problem is the same. Tested on version 2.93.5 with the same addons - no problems.
Now I continue to search for the source of the problem.
Probably found a problem. If you do not turn on denoise, then the error message is not displayed. But if you turn on denoise, get an error and turn off denoise, then the error will still continue to display
Added subscriber: @lichtwerk
Can reproduce in
9dff3de6ac
.For me, this even happens without Denoiser being turned on.
Steps to repro:
test.blend
Preferences
>Interface
>Editors
>Temporary Editors
>Render In
Internal errorto internal error: modal gizmo-map handler has invalid areaAdded subscriber: @JulianEisel
Based on the comment in
wm_gizmomap_handler_context_op
this seems to somewhat be expected behavior (so maybe just removing theprintf
would be fine -- or wording it differently [in that not calling this an error])CC @JulianEisel
