Crash! Calling a modal operator from a load_post handler causes a segmentation fault #92258
5 Participants
Reference: blender/blender#92258
Operating system:MacOS
Graphics card:intel iris graphics
system-info.txt
Broken: 3.0 alpha,
2055ef107a
, master, 2021-10-14Worked: Blender 2.93.4
Our addon Crowdrender uses the bpy.apps.handlers.load_post handler to trigger a modal operator. On Blender 2.93 and below, this has worked since 2.80/2.79. However, in the latest alpha versions of Blender 3.0 this now causes a crash when Blender starts.
If the addon is disabled at startup, however, the crash is avoided and the addon can be enabled successfully without a crash once Blender has started. I can also load a new file and Blender remains stable and running. The problem seems to only occur at startup.
The crash report is here -> Mac crash report.rtf
The scene used is irrelevant since Blender is crashing before the user is able to access the UI.
Please find attached a small addon that reproduces the same issue.
load_post_handler_crash.py
To reproduce the problem,
Blender crashes on startup
Added subscriber: @JamesCrowther
Added subscriber: @Imaginer
Added subscriber: @erik85
I tried this on Win10 but can't reproduce the crash. I also had to modify the script with
from bpy.app.handlers import persistent
and@persistent
decorator on the handler function to make it run.Yeah, I am on macOS, haven't tried this on win10 yet. Copy that on the need to add the persistent decorator. Not sure why its not in the code I attached, its in my local copy. Could have been I uploaded an older version. Sorry about that :S
Just updated the attached addon so it has the @persistent decorator. Looks like I moved the file when I was testing it with Blender 3.0.0 and then uploaded the copy from the old location. I have edited the task above and replaced the addon with the one I was able to reproduce the same crash with.
Can not reproduce either, tested on current master and 3.0.0(
2055ef107a
)Does this still occur for you on latest builds?: https://builder.blender.org/download/daily/
May be you could also add
userprefs.blend
file to test the crashAdded subscriber: @mano-wii
@mano-wii , can you reproduce? Otherwise we can close the task as report went cold for more than a week
I cannot reproduce the problem.
The operator runs normally and intermittently (which is not a good practice as, among other things, it makes Auto Save impossible).
Operating system:
macOS-12.2-arm64-arm-64bit 64 Bits
Graphics card:
Apple M1 Apple 4.1 Metal - 76.3
