OpenColorIO Error #92338
Reference: blender/blender#92338
Operating system:win 10
Graphics card: nvidia3060
Broken: (example: 2.93,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (newest version of Blender that worked as expected)
OpenColorIO Error: Error could not read 'D:\:815@?C:\blender-2.93.5-windows-x64\2.93\datafiles\colormanagement\config.ocio' OCIO profile. Color management: using fallback mode for management Color management: Error could not find role data role. Read prefs: C:\Users\Art\AppData\Roaming\Blender Foundation\Blender\2.93\config\userpref.blend Color management: scene view "Filmic" not found, setting default "Standard".
Added subscriber: @Artur1325
win10
nvidia 3060 6gb laptoop
OpenColorIO Error: Error could not read 'D:\:815@?C:\blender-2.93.5-windows-x64\2.93\datafiles\colormanagement\config.ocio' OCIO profile. Color management: using fallback mode for management Color management: Error could not find role data role. Read p...to OpenColorIO ErrorAdded subscriber: @PratikPB2123
This report does not contain all the requested information, which is required for us to investigate the issue.
Please carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Added subscriber: @rjg
@Artur1325 Do you have the OCIO environment variable set? It seems that Blender tries to load the file from an improperly formatted path.
how to format correctly?
@Artur1325 You would have to check the environment variables in your Windows settings (Open the settings and search for "Environment variables"). You or a software you have installed, may have set the OCIO environment variable to an improperly formatted path that results in Blender looking in the wrong place. Notice how the error message indicates that the path Blender uses combines a path to the
D:
andC:
drive. If this is the case you can either correct the path or remove the environment variable if it isn't needed.This comment was removed by @Artur1325
Added subscriber: @Raimund58
