Default cylinders uneven or "select sharp edges" works wrong #92404
Reference: blender/blender#92404
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.13
Broken: version: 2.93.3, branch: master, commit date: 2021-08-17 18:30, hash:
8b80d19f36
Default cylinders uneven or select edges works wrong
Create a 12 edge cylinder.
Enter to edit mode
use the function "select sharp edges"
put 30-degree select
An expecting result: all edges have to be selected.
The result is no all edges are selected.
bug_9.blend
Added subscriber: @Hrofti
Added subscriber: @ideasman42
In this case using exactly 30 degrees will not always match because of floating point inaccuracy.
Select slightly below 30 to select all edges.
I think 360/12=30 It looks quite an even number.
Added subscriber: @yanush8888
I understood the problem described by Barton, here the problem lies in the direct interpretation of the integer division of the edges from the field, which is of the float type (if you apply the logic of attributes in the SQL), so developers should take into account when building models within the framework of vector construction of the model. That is, this function should not be performed by the end user, but by the system, since the actions you described are a direct hack trick
