node_wrangler no longer works.. #93049
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#93049
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.49
Broken: version: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash:
blender/blender@a791bdabd0
Addon Information
Name: Node Wrangler (3, 38)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
Added subscriber: @Anthony-Abelardo
I tried to reinstall it after shift+a does nothing in shading.
This report does not contain all the requested information, which is required for us to investigate the issue.
Please carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
I reinstalled Blender and it worked. My other PC had no issue. Just used the old userpref file and it was like nothing happen.
The 0.001 mm issue still exist though but it's ok. I just change the mm of the stage if I'm importing .stl files to modify or reference then just ignore the extra 000 (2mm = 2000mm on the edge measure) otherwise I have Massive zooming issues. I still have to scale up 100000% in 3D printing software to get it to work. The issue with that is something is off by 0.02 and things no longer line up.. I should probably just keep it in m format and ignore the other m which I'm going to do now with another launch save.
