Can't launch Blender 2.93.5 #93077
2 Participants
Reference: blender/blender#93077
Operating system: Windows 10 Professionnel 64bits
Graphics card: Geforce GTX970
Broken: 2.93.5
Worked: 2.81
Error : EXCEPTION_ACCESS_VIOLATION
Address : 0x00007FFC88BF432C
Module :
Thread : 000018ec
Switching to fully guarded memory allocator.
Blender 2.93.5
Build: 2021-10-06 06:44:49 Windows release
argv- [x] = E:\BLENDER\blender-2.93.5-windows-x64\blender
argv- [x] = --debug
argv- [x] = --debug-gpu
argv- [x] = --debug-gpu-force-workarounds
argv- [x] = --python-expr
argv- [x] = import bpy; bpy.ops.wm.sysinfo(filepath=r'C:\Users\Sarcive\AppData\Local\Temp\blender\debug_logs\blender_system_info.txt')
read file
Writing: C:\Users\Sarcive\AppData\Local\Temp\blender.crash.txt
Added subscriber: @Romain79
Hi, thanks for the report. Could you load 2.93.5 from
blender_factory_startup.cmd
(located in the same directory whereblender.exe
is?Please also attach crash logs: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#crash-log
Hi Patrick,
Still not launching.
Address : 0x00007FFF6D74432C
Module :
Thread : 00002ed4
Hi, thanks for checking. Could you please add those files?
blender_debug_log.cmd
is)blender_debug_output.txt
blender.crash.txt
blender.crash.txt
Much thanks for your help Patrick. Here the files.
blender.crash.txt
Hi Patrick I still Can't open Blender, Have you managed to take a look at the crash log ?
Thanks.
Hi, please also attach System Info file generated after the crash.
No call stack generated after the shut down so I am not sure about the reason for crash :/
Could you please try again after updating the driver?: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/windows/nvidia.html
Hi Patrick,
My driver has been updated, blender but still crashing at launch.
Where do I finf the System info file ? Nothing appears in Temp dir.
Last thing I've done before crashing was to install addons on blender 2.92 Hardops23_1 ; Boxcutter719_4 ; cablerator1.3.0
Thanks
Hi Patrick,
Find attached My config.
Thanks{F11827399}
Hi patrick,
Here is the system info from the 2.81 running version system-info.txt
Also Let me mention version 2.81 is running but displaying strange artefacts, plese see Gif attached.
Hi, file will generate after the crash along with
as said in #93077#1254224Not sure then. Your driver is also updated. Does this glitches happen for specific file?
Can you reproduce this on recent 2.93LTS?: https://www.blender.org/download/
Hi Patrick,
No systeminfo.text is generated. Please see
I tried launching 2.93.6 2.93.5 2.93.0 None of them are launching.
@Romain79 , does this issue still exists?
Does this happen on [3.0.0 ]] or [ https:*builder.blender.org/download/daily/ | daily builds ?
Factory startup should have worked for you if add-on causing the issue.
Have you tried running
blender_debug_gpu_glitchworkaround.cmd
? That will enable all available workarounds for driver issues.Changed status from 'Needs User Info' to: 'Archived'
Hi Patrik,
Thanks for coming back to me.
The source of the problem was coming from an old wacom intuos driver. Desinstalling it solved the problem.
Thanks
