changing a material in the properties panel causes geometry node modifier to recalculate. #93148
Reference: blender/blender#93148
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-11-11 18:53, hash:
0533f2851e
changing a material in the properties panel causes the geometry node modifier to recalculate even if the material is not in use. For complex node trees this can result in 60 second waits for nothing to happen other than the material to change in the properties panel. Happens with or without any set material or set material Index nodes in the tree, and even if the material is not in use on the object.
2021-11-17 02-00-12.mp4
Added subscriber: @3di
Hi, thanks for the report.
I am not sure if it's related to Geometry nodes. Does this happen when you apply modifier?
Perhaps the same issue as reported in #94609 (Modifiers are always reevaluated when using an image texture data-block)
Can you provide a sample .blend file?
Does this issue persist on recent development builds?: https://builder.blender.org/download/daily
@3di Hi, any updates? Otherwise I will have to close the task since its more than a week without reply :)
Hi, here's a file. Open the file click suzanne, go to the material panel and click the 'new' button to add a new material. Blender will freeze for several seconds whilst the geometry node modifier re-calculates needlessly.
geo node update bug.blend
geo nodes needs to check if a changed/new attribute in use by the node network? if not do nothing. If it has changed, check the hash of the attribute for all elements combined (just in case the user/external functions have refreshed but not changed.)
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Thanks for the file. Can confirm.
This even happen when I use primitive node as input. Which I think shouldn't happen as material slots are not directly used by mesh created from scratch (with GN nodes).
(eg. input UV sphere node to the same node tree).
@HooglyBoogly , can you check?
I get that if geo nodes creates new geometry, that the attributes need propagating to the new elements, but that should be done without re-calculating the tree if the result is unaffected by that attribute.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
This isn't a bug, material assignments can change the evaluated state of a mesh, so the modifier stack must be reevaluated. Theoretically there could be checks if the updates could be avoided some of the time, but that's not something Blender really does anywhere, and the information will not always be easy to know statically. The dependency graph just doesn't have the opportunity for such fine-grained dependencies at the moment.
Just a thought, could the geometry node modifier have it's own inbuilt logic so that when the modifier stack updates, it can see if an update is necessary based on the hash of modifiers before it and their parameter value? I was able to do this in the compositor to achieve real time interaction and caching during playback without referring to the depsgraph (because of the shortcomings you mentioned). Then the only thing to check would be any new or updated attributes to see if they're in use by the tree, if they contribute to the outcome of the tree, and if they've actually changed (based on the hash). If not, maybe the geometry node code itself could update/write the attributes without executing the whole tree needlessly?
Yes, I think that is mostly possible, we've discussed it a bit before anyway. I don't think it's quite the time to work on that yet, with some designs for an "edit mode node" still up in the air. But I think it will happen eventually.
