Flip Mesh Faces Node #93569
10 Participants
Reference: blender/blender#93569
Currently there is no way to flip normals in geometry nodes. This node would make that possible
by flipping the winding order of selected faces. The node is purposely not called "Flip Normals",
because normals are derived data, changing them is only a side effect.
The real change is that the face corners of every polygon are reversed.
{F12679512 size=full}
The node should have a mesh input and output, as well as a selection input (evaluated on the face domain). Only face corners attributes and indices will be affected by the node.
Implementation
MutableSpan::slice
andMutableSpan::reverse
should be helpful.MLoop
can be simply reversed, but the edge indices will have to be updated.Further Questions
N/A
Added subscriber: @GeorgiaPacific
Added subscriber: @filippo_f
Hi, I am in the process of implementing this node. I have a pair of problems I stumbled across, and wanted to hear an experienced dev's opinion on this. I hope these to be legit questions.
1.This question is about performance: my approach to this was to iterate trought the selected faces first, and then inside every face reverse the MLoop's order. This algorithm should take O(n), where n is the vertices, since I need to iterate trought every vertex of the MLoop in order to reverse it. Is this where the MutableSpan::reverse should take place? I didn't find any reference to this method inside the source code, but I'm sure this would help making the algorithm more efficient and definitely shorter.
2.In the last point you said that edges indices need to be updated after reverse. My question is, are edges indices relative to the face they belong to? I.e. every time I move a face further will my index start from 0 again? Or are all edges indices linked togheter inside the same mesh?
Edit: I found the BLI_span header file, my bad!! That gave me the answers I needed
Hey, great to hear you're working on this!
FieldEvaluator
offers a method calledget_evaluated_as_mask
. This gives you only the selected indices, so you don't need to iterate over every single face. That's helpful when only a few faces are selected.MEdge
array. EachMLoop
has an index of a vertex, and then the index of the subsequent edge. When an edge's vertex order is swapped, which edge is the "subsequent" edge also changes.Thanks! That was clarifying. I still don't comprehend the edges part. I mean, I tried everything after reversing the loop. I tried swapping the edges indices, but the mesh returns to normal after I apply the modifier, like nothing happened. Maybe I'm missing something at the end of the method? Like updating normals or such? It looks like it's working when the modifier is active but when applied its effects disappear and the normals return like before.
Also if I may ask, what's the difference between these two ways of reversing a face's loops? Are both of them valid?
a.
MPoly *poly = &mesh->mpoly[poly_index];
MutableSpan loop_span = loops.slice(poly->loopstart, poly->totloop);
loop_span.reverse();
for(const int poly_index : selection){
BKE_mesh_polygon_flip(poly, mesh->mloop, &mesh->ldata);
Maybe these drawings will help:
MLoop
. (It should work for face corner domain attributes though).There's also a performance aspect.
The problem with
is that it works on every every single attribute at the same time, seeCustomData_swap
. This is needlessly slow, mostly because it doesn't play well with caching on CPUs.The difference is with the loops:
A:
B:
B should play much better with caching, especially since in this case the operation is quite simple, so the algorithm will hopefully be memory-bound.
Enlightening, thanks!!
Added subscriber: @Akash-R
Added subscriber: @Garek
Added subscriber: @niyanx
Added subscriber: @unizen
Added subscriber: @alan_void
Added subscriber: @Nathan-Mossaad
Removed subscriber: @Nathan-Mossaad
