Blender 3.0.0 crashes when rendering both Evee and Cycles on Mac #94198
Reference: blender/blender#94198
Operating system: macOS-10.14.6-x86_64-i386-64bit 64 Bits
Graphics card: Intel Iris Pro OpenGL Engine Intel Inc. 4.1 INTEL-12.10.30
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
The crashes happen when attempting to render a scene and they seem to happen when changing from Cycles to Evee and the other way around.
I have tried some various files and settings but the crashes seem to happen only in rather complicated files, i.e. when I have geometry nodes, with complex shader nodes and/or in animation with many objects. In several occasions I have – strangely – been able to render in, for example Evee, when I restart Blender after a crash and try again, sometimes in my third attempt.
GeoCelticSpiral.blend
Crash report Blender 3 Alpha 01.01.22.txt
Added subscriber: @Tora-Victoria
File used on task
ProceedGeoNodes.blend
Thanks for the report. Please provide crash logs generated after the crash: https://docs.blender.org/manual/en/dev/troubleshooting/crash.html#crash-log
I am not able to reproduce crash on Windows (tested on 3.0.0 and current master)
Added subscriber: @jenkm
Works fine for me.
Hi guys
Here is the crash report. Yes, it is from 3.1 Aplha but the same happens in 3.0
Here is the file
Hi, Thank you for those files. When exactly crash appears? Does this happen on rendering in viewport?
Are you able to reproduce crash with every .blend file (even with default scene)?
I didn't understand the call stack mentioned in the crash report. @jenkm , do you get that?
Hi,
Q. When exactly crash appears?
A. The crashes happen when attempting to render a scene and they seem to happen when changing from Cycles to Evee and the other way around.
One thing – when rendering animations – both as image sequences and video files, Blender crashes frequently; sometimes immediately but more often midway through . I have applied a python render script to avoid these crashes as suggested by Chris P seen here: https://www.youtube.com/watch?v=ydAmFR2wN9w . All of this started to happen for me in version 3.
Q. Does this happen on rendering in viewport?
A. No. There is a thing about the viewport however: After version 3., when going into the shader window, the material preview starts very slowly – like 3 -7 sec freeze. Another thing worth mentioning is that after version 3 there is no progress visible when rendering a frame/image in Cycles. The only thing visible is the progress bar at the bottom of the main Blender window – the render tile animation is gone when viewing the progress in the image editor pop-up window.
So to sum up: The crashes seem to be associated with changing render engines, rendering animations and complex scenes.
Hope this helps.
Hi, thanks for clarifying the issue. Doesn't crash here when switching between render engine.
Crash occurred after rendering specific number of frames? or just random?
@jenkm , are you able to reproduce with those steps on MAC?
Hi @Tora-Victoria, can you check again with latest development builds?: https://builder.blender.org/download/daily
If persists, I need to ask someone to test on Mac. It doesn't crash for me.
