OBJ/MTL Material Roughness imported and exported inaccurately. #94516
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#94516
Graphics card: NVIDIA GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.09
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
blender/blender@84da05a8b8
Material Roughness range is off in the blender .obj exporter and importer.
Currently it is based on a 0-900 smoothness scale ("Ns" in the .mtl) when it should be based on a 0-1000 range according to this website about the format:
http://www.paulbourke.net/dataformats/mtl/
The problem is that other programs are using a 0-1000 scale for the import and every time you exchange between the programs it slowly gets more and more rough.
It's easy to fix, I've done it myself just by changing a couple lines in the import/export python scripts.
We could make this part of a bigger change integrating the PBR mtl tags outlined here:
http://exocortex.com/blog/extending_wavefront_mtl_to_support_pbr
RoughnessBug.blend
RoughnessBug.obj
RoughnessBug.mtl
Added subscriber: @Christian-Coppoletti
Added subscribers: @mont29, @PratikPB2123
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Hi, thanks for the report. I see, range 0-900 is said in the code: https://developer.blender.org/diffusion/BA/browse/master/io_scene_obj/export_obj.py$77
Hi @mont29 , can you look at this issue? On website (s) they have given Specular exponent range from 0 to 1000.
Indeed... Will commit fix for this, note that it will slightly 'break' compatibility with existing files exported from Blender though, since the new imported value from them will be slightly different.
This issue was referenced by
f26299bacc
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
