Snapon does not work #95074
2 Participants
Reference: blender/blender#95074
Operating system:
Graphics card:
Broken: (example: 2.80,
edbf15d3c0
, master, 2018-11-28, as found on the splash screen)Worked: (newest version of Blender that worked as expected)
Trying to make a donut, I use the Snap. --> Face --> Project individual element (For drooping icing). Then I click the bottom dot --> G key (to drag) instead it drags the whole icing(torus 2) on the other side creating a distorted image
Added subscriber: @cdbake07
Hi, thanks for the report. Looks identical to this report: #94686 (Non selected verteces that are on the opposite side/through the mesh are being moved.)
Do you mean the same? Then it's working as intended
Please check if you can reproduce when Projected from View is
Disabled
in Proportional Editing popup.Also, This report does not contain all the requested information, which is required for us to investigate the issue.
Please carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
