Dragging Material from Asset Browser (Link mode) to Viewport empty space removes this material from all objects #95636
7 Participants
Reference: blender/blender#95636
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.29
Broken: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
Also broken in: version: 3.0
Dragging a Material from the Asset browser to empty Space in Viewport removes the Material from all objects in the scene
Added subscriber: @Lumpengnom-3
Added subscriber: @lichtwerk
Can confirm (but only in
Link
mode).Also getting this (which might not be related, this seems correct):
Will set this to High prio (even though this is not a regression, seems like it never worked)
Dragging Material from Asset Browser to Viewport removes this material from all objectsto Dragging Material from Asset Browser (Link mode) to Viewport empty space removes this material from all objectsHere it happens in "link mode" and also in "Append (Reuse Data)" Mode. Not in "Append" mode, though.
Added subscriber: @Wovchick
Added subscribers: @mont29, @dr.sybren
This seems to have something to do with the way the material is imported:
This requires some more knowledge than I have of how the "append/link on drag" and "use on drop" collaborate with each other. @mont29 do you know what could be the root cause here? I'm guessing there is an implicit assumption somewhere in the code that a dragged-and-dropped asset is actually going to be linked to something, and if that isn't the case, it'll be deleted. In this case, it means that a pre-existing material is deleted, which is not supposed to happen.
That backtrace is actually not relevant, since that specific deletion is valid (it's deleting the linked version of the material, not the local one, which is expected behavior when re-using an appended ID instead).
Deletion of the local one happens from
WM_drag_free_imported_drag_ID
, which unconditionally deletes the dragged ID when dropped on no valid target. Fixing this is relatively trivial:Unfortunately, while digging a bit more, I found that there are a lot more issues when you start mixing
Link
andAppend
modes from the asset browser, e.g. once a material has been appended, it becomes impossible to get it linked using the drag'n'drop feature... This needs more investigation.Another question raised here is what happens to indirectly linked/appended data (like nodetrees for a material, geometry and materials for an objects, etc.). Afaict currently, those will remain around as orphaned data, which is also a fairly bad behavior.
@JulianEisel if you are fine with proposed fix above, would commit this for 3.1 since this issue is very bad.
And I think we need to create a task to properly handle deletion of 'aborted' dragged data, because right now this is handled in a very poor way.
If you say this fix is what we should do then I'm fine with it of course.
Quite some things changed since this ID freeing for aborting was added, and it wasn't tested a lot since then I think. Now the temporary ID loading code may be a better way to go about it.
This issue was referenced by
66328db703
