Geometry node don't expose materials to the solidify modifier #95903
5 Participants
Reference: blender/blender#95903
Operating system: Windows 10
Graphics card: Nvidia RTX 2060
Broken: blender-3.1.0-beta+v31.93cc89247010
Worked: 3.0.1
When using a geometry node to generate a mesh, and then applying a solidify modifier to it, the materials are not properly exposed and not or wrongly assigned to the final mesh
The resulting tube doesn't show any of the materials.
Now the resulting tube displays the last material of the list on some parts, but this is still not it.
Then add a screw modifier to extrude it, after the geometry node modifier and before the solidify modifier
Set its angle to 0° and Screw value to 1
Now the resulting tube is only displaying the first material
Now the resulting tube displays all the materials properly.
Note : it is not obvious, but it is mandatory to join the original geometry into the end result to get the materials correctly propagated to the output.
Maybe this could be more clearly explained or simplified somehow.
Sample file here reproducing all cases mentionned above :
solidify_material_bug.zip
Added subscriber: @Alesk
I think this got affected in
f5ce243a56
@JacquesLucke, can you check?
Not bisected this time but it's actually broke between:
b647509913
-644eb68524
I'm not sure I'd consider this a bug. If the original mesh is empty, I'm not sure it should have an effect on the result. i.e. I think an empty mesh is the same as empty geometry.
At least I think that's the design we've been operating with-- maybe I'm wrong though.
I find it hard to follow the details of the report. Think that's mainly because it's not entirely clear what the actual and expected behavior is for one very specific example.
In the file some material slots are on the mesh and others on the object, which makes it harder.
Material index propagation when there are no faces using the materials is not guaranteed by the Join Geometry node currently. It could also just drop the unused materials.
Maybe this is related to #95417.
@JacquesLucke, open .blend file and notice the difference.
(note: I haven't seen the file which reporter has attached)
the expected behavior is to get the solidify modifier give the same result, whether it receives as input a standard mesh or a geometry node result.
In this case the expected result is to have material 0 on the original mesh (before solifidy) and the materials 1 and 2 assigned to the offset and rim parts of the solidify resulting mesh.
During my tests I've put the materials (the 3 of them, in the same order) on the object and on the mesh to see if it could help somehow.
Result : materials on mesh are ignored, only matrerials on objects are effective.
Yes, it could be related.
If the mesh data or the object are referring to a list of materials, having an empty mesh ( or only some vertices and no faces ) should not be a problem to properly access this list of materials.
Added subscriber: @dfelinto
Not entirely sure yet that this is a bug, but better to investigate further together with the other material bugs.
