GPU subdivision: Last subsurf modifier is always used for GPU subdivision, even when disabled. #96283
7 Participants
Reference: blender/blender#96283
Operating system: Arch Linux (last updated Mar 10, 2022)
Graphics card: NVIDIA GeForce GTX 1070
System Info: system-info.txt
Broken: 3.1.0,
c77597cd0e
Worked: 3.0.1
This bug only takes hold when GPU Subdivision is enabled.
When multiple SubSurf modifiers are added to an object, the last one in the stack determines the subdivision levels even when it is disabled.
This screenshots showcases the setup and issue:
This affects not only the viewport, but also renders:
Additionally, setting the subdivision count to 0 causes a crash (image attached is a GIF):
Based on the default startup file:
I've attached an example file showcasing the issue here: gpu_subdiv_bug.blend
I understand stacking SubSurf modifiers is a little unusual. I use this often in conjunction with drivers to switch between a high-fidelity and low-fidelity SubSurf that are stacked on top of each other.
Added subscriber: @lumakyu
#97534 was marked as duplicate of this issue
#97361 was marked as duplicate of this issue
#96565 was marked as duplicate of this issue
Added subscribers: @kevindietrich, @Alaska
I can confirm this issue, even in latest master.
CC @kevindietrich
Added subscriber: @Raimund58
Added subscribers: @Ethan-Hall, @PratikPB2123, @YAFU, @iss
Wrong level count with multiple SubSurf modifiers (GPU Subdivision only)to Last subsurf modifier is always used for GPU subdivision, even when disabled.Last subsurf modifier is always used for GPU subdivision, even when disabled.to GPU subdivision: Last subsurf modifier is always used for GPU subdivision, even when disabled.Added subscriber: @lichtwerk
Talked to @kevindietrich , setting to High prio (since it is a bug in a new feature according to the playbook
Added subscribers: @Mets, @HooglyBoogly
Added subscriber: @Solus-3
This issue was referenced by
68ca12a7fc
