Texture Baking #96300
2 Participants
Reference: blender/blender#96300
Windows 10
GTS 450
3.1.0
c77597cd0e
Texture baking not working.
When I try to bake a texture in this version, I am immediately given an empty transparent image.
In version 3.0.1, everything works fine.
Gif:
Added subscriber: @iKotyaX
Hi, thanks for the report. Can not confirm on 3.1 and 3.2
Can you give us more clear instruction to replicate the problem?
Partial Image updater has probably caused this.
Test File:
#96300.blend
Hello,I'm just trying to bake the texture,
Here are the steps I follow:
2.Color change
3.Adding an empty texture to node editor (1024x1024)
(Even if you change any parameters, for example, bake only the color, the image will still be transparent)
Hi, I still can not reproduce. Can you test again on latest 3.2 build?: https://builder.blender.org/download/daily/
Also, any luck with factory prefs?: {nav Edit > Preferences > Save & Load (3 horizontal lines) > Load Factory preferences}
Are you able to see texture after resizing Image editor area? Then issue is likely caused by
507a4deef1
or5e9c1feb8a
@iKotyaX hi, have you tried replicating the issue on 3.2 build?: https://builder.blender.org/download/daily
Do you see the exact same issue when you bake image texture in the file I had uploaded?
