Subdivision Surface Crash #96478
Reference: blender/blender#96478
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 4600 Intel 4.3.0 - Build 20.19.15.5171
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-03-14 00:08, hash:
b959f603da
Blender crashes when I set the Subdivision Surface Levels Viewport to 6.
surface_subdivision_crash.blend
Added subscriber: @(Deleted)
Added subscriber: @Alaska
This is most likely caused by the GPU subdivision surface modifier introduced in Blender 3.1. Something you can do to try fix this is see if updating your GPU drivers resolves the issue.
If that doesn't help, then are you able to upload the crash log. This can be done by following these steps:
C:/tmp/blender.crash.txt
and upload it to this site.Are you also able to upload your system information. This can be done by following these steps:
If updating your GPU drivers doesn't help then you can try disabling GPU subdivision and see if that helps. This can be done by following these steps:
Viewport
tab.Viewport
tab, and in theSubdivision
section disableGPU subdivision
.I tried going to Edit >Preferences and, the GPU Subdivision is off. So I tried to enable it and, surprisingly, Subdivision Surface seemed to work much better when I enabled GPU Subdivision. Anyways, I'll still provide the files that you want to me upload.
Ah, I can't find blender.crash.txt on C:/tmp/blender.crash.txt but this is the system info file.
system-info.txt
The file should be there if you follow these steps:
If you open a file. For example
cats.blend
then follow the steps to get Blender to crash, then the file will beC:/tmp/cats.crash.txt
If you reboot your computer, the file will disappear.
Added subscriber: @deadpin
Windows works differently than other platforms and the crash file is written to the following per-user location:
For example with a crash here:
Writing: C:\Users\jesse\AppData\Local\Temp\CrashAllObjects.crash.txt
It's also not cleared on reboot typically. You can try checking there to see if you have a crash file after you attempt things again.
Ah, I checked on the Temp folder but I can't see subdivision_surface_crash.crash.txt. Please check the image below:
blender_debug_log.cmd
orblender_debug_gpu.cmd
(in same directory where blender.exe is located)blender_debug_output.txt
file hereUpgrade your GPU driver to the most recent one: https://docs.blender.org/manual/en/3.2/troubleshooting/gpu/windows/intel.html
Reporter's account does not exist anymore. So closing this report straightaway :)
