Stereoscopy with Motion Blur crashes in Eevee #96572
Closed
opened 2022-03-17 20:54:59 +01:00 by Zach Bennett · 12 comments
Operating system: Windows 10
Graphics card: RTX 2070 Super
Broken: 3.1.0
Worked: 3.0.1
Caused by 4e78a7360e
When trying to render, blender crashes while Motion Blur is enabled and Stereoscopy is enabled. This only happens when using Eevee to render, it works in Cycles. This happens with both Stereo 3D and Multiview in the Stereoscopy settings.
#96572.blend
Open file and Render image using Eevee
**System Information** Operating system: Windows 10 Graphics card: RTX 2070 Super **Blender Version** Broken: 3.1.0 Worked: 3.0.1 Caused by 4e78a7360e When trying to render, blender crashes while Motion Blur is enabled and Stereoscopy is enabled. This only happens when using Eevee to render, it works in Cycles. This happens with both Stereo 3D and Multiview in the Stereoscopy settings. **Exact steps for others to reproduce the error** [#96572.blend](https://archive.blender.org/developer/F12932438/T96572.blend) Open file and Render image using Eevee
Author
Added subscriber: @WretchedShrub
Added subscriber: @iss
Trace:
>	blender.exe!BLI_mempool_len(const BLI_mempool * pool) Line 436	C
 	blender.exe!BLI_ghash_free(GHash * gh, void(*)(void *) keyfreefp, void(*)(void *) valfreefp) Line 865	C
 	blender.exe!EEVEE_motion_blur_swap_data(EEVEE_Data * vedata) Line 508	C
 	blender.exe!eevee_render_to_image(void * vedata, RenderEngine * engine, RenderLayer * render_layer, const rcti * rect) Line 569	C
 	blender.exe!DRW_render_to_image(RenderEngine * engine, Depsgraph * depsgraph) Line 1979	C
 	blender.exe!engine_render_view_layer(Render * re, RenderEngine * engine, ViewLayer * view_layer_iter, const bool use_engine, const bool use_grease_pencil) Line 900	C
 	blender.exe!RE_engine_render(Render * re, bool do_all) Line 1021	C
 	blender.exe!do_render_engine(Render * re) Line 1060	C
 	blender.exe!do_render_compositor(Render * re) Line 1198	C
 	blender.exe!do_render_full_pipeline(Render * re) Line 1467	C
 	blender.exe!RE_RenderFrame(Render * re, Main * bmain, Scene * scene, ViewLayer * single_layer, Object * camera_override, int frame, const bool write_still) Line 1868	C
 	blender.exe!render_startjob(void * rjv, short * stop, short * do_update, float * progress) Line 661	C++
 	blender.exe!do_job_thread(void * job_v) Line 369	C
 	blender.exe!tslot_thread_start(void * tslot_p) Line 205	C++
 	[External Code]
Trace: ``` > blender.exe!BLI_mempool_len(const BLI_mempool * pool) Line 436 C blender.exe!BLI_ghash_free(GHash * gh, void(*)(void *) keyfreefp, void(*)(void *) valfreefp) Line 865 C blender.exe!EEVEE_motion_blur_swap_data(EEVEE_Data * vedata) Line 508 C blender.exe!eevee_render_to_image(void * vedata, RenderEngine * engine, RenderLayer * render_layer, const rcti * rect) Line 569 C blender.exe!DRW_render_to_image(RenderEngine * engine, Depsgraph * depsgraph) Line 1979 C blender.exe!engine_render_view_layer(Render * re, RenderEngine * engine, ViewLayer * view_layer_iter, const bool use_engine, const bool use_grease_pencil) Line 900 C blender.exe!RE_engine_render(Render * re, bool do_all) Line 1021 C blender.exe!do_render_engine(Render * re) Line 1060 C blender.exe!do_render_compositor(Render * re) Line 1198 C blender.exe!do_render_full_pipeline(Render * re) Line 1467 C blender.exe!RE_RenderFrame(Render * re, Main * bmain, Scene * scene, ViewLayer * single_layer, Object * camera_override, int frame, const bool write_still) Line 1868 C blender.exe!render_startjob(void * rjv, short * stop, short * do_update, float * progress) Line 661 C++ blender.exe!do_job_thread(void * job_v) Line 369 C blender.exe!tslot_thread_start(void * tslot_p) Line 205 C++ [External Code] ```
Member
Member
Member
Crash introduced after this commit- 4e78a7360e
@JacquesLucke ^
Crash introduced after this commit- 4e78a7360e @JacquesLucke ^
Member
Only had a quick look so far. Asan shows that it is a use-after-free bug: P2840.
Only had a quick look so far. Asan shows that it is a use-after-free bug: [P2840](https://archive.blender.org/developer/P2840.txt).
This issue was referenced by e5487a81a4
This issue was referenced by e5487a81a414e0564a977f442e690f38d9ae4ebf
This issue was referenced by 9ed63ebb45
This issue was referenced by 9ed63ebb458141661bcbfe81c187f843e9dcbacf
Member
Jacques Lucke self-assigned this 2022-03-21 10:06:19 +01:00
Member
Broken: 3.1.0
@JacquesLucke hi, thanks for the fix. How about backporting this commit for corrective release?
Change appears safe for backporting :)
> Broken: 3.1.0 @JacquesLucke hi, thanks for the fix. How about backporting this commit for corrective release? Change appears safe for backporting :)
5 Participants
Reference: blender/blender#96572
