Merging/joining into single object can massively increase file size #96926
6 Participants
Reference: blender/blender#96926
NOTE: Other triagers: please dont close this after a week, providing a repro case might take a bit.
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.29
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
Worked: Not sure.
Single object massively increases file size vs separating the mesh into multiple objects
Start Blender and delete all objects in the scene.
Create a new collection called "Suzanne."
Add a Suzanne to this collection.
Select Suzanne and go to Edit mode
Select All
Go to Mesh > Split > Faces and Edges by Vertices
You now have a single object that consists of separate faces.
Go to Object Mode
Save the file as "Suzanne Whole"
Go back to Edit mode
Select All
Separate by Loose Parts
Go back to Object Mode
Save the file as "Suzanne Parts"
You will now see that the Suzanne Whole file is substantially larger than the Suzanne Parts file.
Contrary to what would be expected, having hundreds of objects drastically reduces the file size. However having the same amount of geometry in a single object causes the file size to balloon up, not by a small amount, but by a massive amount.
When this is done with a more complicated model (in the tens or hundreds of thousands of polygons), it can result in a difference of a file going from 200MB to 5GB.
Suzanne - Whole.blend
Suzanne - Parts.blend
Added subscriber: @stevewarner
#71823 was marked as duplicate of this issue
Many mesh objects balloons file size vs many meshes in a single objectto Single object massively increases file size vs separating the mesh into multiple objectsAdded subscriber: @PratikPB2123
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Thanks for the report.
I don't think this is a bug. New object gets created for the every loose face you've.
Also, shared vertices gets duplicated for every face next to it so I expect the file size to increase.
I'll defer this report to developers just in case I'm missing something.
Added subscriber: @lichtwerk
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Not sure I understand correctly:
Suzanne - Parts
is a lot bigger in filesize thanSuzanne - Whole
(3MB vs 328kB).This is to be expected, but it seems you are observing the exact opposite?
@lichtwerk , I think I did not read last few lines of the report carefully :p
What I read is Mesh converted to loose part is more in file size than the mesh as single object
Which is expected I believe... (because each face is now a separate object)
Sorry for the confusion. I think using Suzanne is muddying the waters. Let me give the real-world example that alerted me to this as I think that might help.
This is a proposed theme park land that we're working on. It has over 21,000 objects and over 2 million polygons.
The file size on disk for this model is 368 MB
As you can see, the environment has all kinds of detailed models in it.
I don't need most of these for my current task, so the models circled here I'm going to delete.
Now I have just the show building as seen here:
The scene is notably lighter as it now only has 333,000 polys. But for some strange reason, my number of objects has increased.
I put the roof of the building in a separate collection because I'll need to show the building with the roof on, and then with the roof off with the rides in it.
The file size on disk is now smaller as expected. It's down to 251 MB. Great.
I'm going to be sending this to a co-worker, so I want to simplify the scene. I'm going to take all those objects that make up the rest of the building and simply join them into a single object. That way, there will only be two objects in the scene. The building, and the roof. Easy. Select all the objects in the Building collection and press CTRL+J. Then wait.
Great! It worked. I now have two objects in my scene. The poly count hasn't changed. Still at 333,000 polys. And my outliner is nice and clean. Just two objects. However Blender sometimes stores junk data. Let's purge the Orphan data.
Yep. Looks like there's a bunch of meshes left over. Purge away!
Great! Now my scene is nice and clean. Time to save and send to my co-worker.
Wait! WTF? My file size on disk has gone to a whopping 4.89 GB.
The entire model with all the stuff in it was only 368 MB. But by deleting files and simply joining thousands of objects into one single object, my file size has gone to nearly 5GB!
I've inspected the model. Deleted unnecessary materials. Cleared out any cached images. How does a scene go from 300MB to 4GB when I've deleted things?
So now to try this on a simple scene, because I can't send you this model.
Create a Suzanne. Unweld all the verts and separate the faces into their own meshes. This will represent the city. Lots of tiny individual objects. Save the file and name it Parts. There are 500 objects (each a single face) and 1,968 verts. It's 3.12 MB on disk. Now take those 500 objects and join them into a single object. Don't merge verts. Now you have a single object, but you still have the same number of faces and the same number of verts. So the only thing that's changed is the number of objects. from 500 down to 1. Save the file. Name it whole. Now you get a file that's 321K on disk.
Well, hell. That's now the OPPOSITE of the problem that I'm having, where I'm getting a small file size with LOTS of objects but a HUGE file size with only 2 objects.
So I file the bug report, because either way you slice it, it doesn't make a lot of sense. You have a scene with the same amount of polys. The same amount of verts. The only difference is the number of container objects for the mesh parts. And the file size is wildly different.
I hope that makes sense. Something seems really off here.
Hi, thanks for the information.
Appears to be same as said here: #71823
Disable Global Undo and see if that makes any difference when joining objects
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscribers: @mont29, @ideasman42
Hm, I dont understand why this or #71823 (Merging objects that use meshes with users count of 1 increases the file size massively) are not bugs tbh.
@ideasman42 , @mont29 : could you comment?
Well, having many "container" objects increasing the file size does make a bit of sense I think
In any case, there seems to be something wrong when {key Ctrl J} joining in certain cases, will try to come up with a repro case, @stevewarner : it would still help a lot if you could share one, too
Added subscribers: @roxlu, @AnthonyEdlin
Single object massively increases file size vs separating the mesh into multiple objectsto Merging/joining into single object can massively increase file sizeChanged status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Until we have found such a repro case, will set status to "Needs Information from User" though.
Just wondering if this could possibly be related to #98249?
We cannot keep an incomplete report open forever, will close it for now. Can easily be re-opened if/when we get a reliable reproducible case.
#71823 (comment)
Same issue, screen record supplied.
So this was reported again in #111564
And the reason seems to be that joining does not limit the number of UV layers to 8 (as done elsewhere in blender).
So you might end up with hundreds or thousands of UV layers (and each of them occupying memory for a -- now very large -- mesh).
I think this is probably what was the issue in #71823 as well.
I think the situation should still be improved:
I will open another issue for this shortly...
I opened #111608 for this.
