Geometry Nodes does not show instances of collections in "Render image" ok, while both cycles and eevee render those correctly in Viewport #97373
Reference: blender/blender#97373
Operating system: Ubuntu 20.04.4 LTS
Graphics card: GeForce GTX 1650
Blender Version 3.1.2
Broken: 3.1.2 daily build April 15, 01:58:06,
cc66d1020c
as well as earlier versionsShort description of error
Instances made with geometry nodes don't show collections in Render image, unless the collection itself is rendered in the image, too. Why this is serious bug and not a feature is explained below. Also note that both cycles and eevee do render the geometry nodes correctly in Viewport, although not in the final Render image.
Start a new general blender file
Add UV sphere, and move it slightly away from the cube, so that you now see both the cube and the sphere
Make a new collection, and move the cube into that collection
Go to Geometry Nodes workspace, select the sphere, and click "+ New". You now have "Group Input" ----> "Group Output" for the sphere shown in the Geometry Nodes editor
Drag the new collection containing the cube into the Nodes editor. It is shown as "Collection Info" box within the editor.
Connect the Geometry output from the "Collection Info" to the geometry input of the "Group Output". The sphere changes into a cube, and so you see two cubes.
Hide the collection containing the cube both from Viewport and from Renders by clicking the respective eye and camera icons on the right side of the collection name
Now you see just one cube in Viewport. It is where the sphere was located. This perfect as it should be. And it doesn't matter which kind of visual or which workspace you have in Viewport. All of them show one cube, from the wireframes and solid modes to eevee and cycles rendered scenes - as long as eevee and cycles are rendered in Viewport.
(9. Note that if you unhide the collection in the Renders by clicking the crossed camera icon, and then F12 to render, you shall see two cubes. That rendered image is right and ok as such, but this behavior shows a current requirement that the collections themselves must be clicked unhidden in Renders, so that one could use instances of a collection in the Geometry nodes. This is a serious bug that is hard to circumvent.)
No - that is not a correct feature but a bug. A practical example illustrates:
Make some complicated object, for example a small spaceship, and put all of its components into a collection. So far so good.
You wish to make an animation of a fleet of 100 of similar spaceships engaged in some situation and flying in the scene.
A beautiful method to achieve is this by geometry nodes. The original spaceship collection would be hidden from Viewport and from Renders, since you are not using it and not moving it around. You are using it just as model for you fleet's ships.
You make your fleet, and make it move by some logic, and everything looks great in Viewport even when rendered with cycles. But when you begin to render your final images, no spaceship will be seen, because your collection was hidden.
Ok, perhaps you just unhide the collection and use it as one your ships? No good, since when you rotate or move your collection, all of the geometry node instances (your 99 other space ships) move and rotate similarly as well. The collection has to remain unmoving and unrotating, at origin. And that spaceship will look pretty stupid, just standing still while all the other ships move around. (Note that even if some future versions of blender would make it possible that the collection itself and the geometry node instances could move independently from each other - so that e.g. rotating the collection would not rotate the instances - it would still be wrong to require that the original collection is visible in the scene to have those geometry node instances in the final Render image. For the reasons that has been said this far, and also because then one would need to make two separate modules for moving and rotating the spaceships in the scene. One for moving the collection and its single spaceship, and one for moving all the 99 other spaceships that are generated by geometry nodes! Right way is making all of the 100 spaceships with the geometry nodes, and making just one module/logic that move all those spaceships in a way that looks good and consistent.)
Also, you cannot hide the unmoving collection spaceship by scaling it to zero size, because all of the other spaceships would scale similarly with the collection.
Maybe put the camera so that the collection is behind it? Then it wouldn't matter, even if the collection is unhidden and just standing still at the origin...? Well, this would be really clunky workaround, and even that wouldn't work well in a general case, since you might need to turn the camera to different directions, if you are for example following some particular spaceship.. So the (unmoving) collection could become visible in such cases.
A functioning hack would be positioning our camera, scene and everything that is interesting say 10,000 units away from the origin, and the collection would be at origin. This way the collection would be too small and too far to be seen in Render image, even if it is unhidden. Yet realistically, this is not the right way to do it...
There has been a very short bug report that relates to part of this, but it didn't make the real problems very understandable. It was https://developer.blender.org/T93429
Added subscriber: @boson
Thanks for the detailed report. Could you upload a file with the example set up? This makes it much easier to discuss the problem, since we can both use the same reference.
Geography Nodes does not show instances of collections in "Render image" ok, while both cycles and eevee render those correctly in Viewportto Geometry Nodes does not show instances of collections in "Render image" ok, while both cycles and eevee render those correctly in ViewportAdded subscriber: @PratikPB2123
Here are files that Hans requested.
So Viewport rendering is always ok. If the collection is hidden in Renders (=the camera icon is crossed next to collectionname ), then Render image does not show instances of collections made with geometry nodes.
minimal example.blend A minimal reproduction of the bug, like the bug report steps 1-8. Select viewport rendering, so that you see cycles and eevee render one cube in the scene in Viewport. Press F12 to Render image, and you will notice there is nothing in the image - unlike in Viewport.
simple spaceship example.blend I made also a better example, a crude spaceship animation like the one envisioned in the bug report. This will illustrate more clearly why Viewport rendering is right and Render image rendering is wrong, and not the other way around.
Select Viewport rendering icon so that you render with cycles (or with eevee) in the Viewport.
Then make the animation play in Viewport by pressing the spacebar. A large number of spaceships is moving towards the horizon. This is the expected good situation, as it should be.
Make a final rendering of some frame with Render image from Render menu or with F12. There is nothing in the image!!!
Change the spaceship collection visible in Renders by clicking the crossed camera icon next to the spaceship collection name, and render again with F12. Now all the instanced spaceship will be shown, but regrettable also the original spaceship collection ( =the huge spaceship at the center) will show in the final rendering.
Click the eye icon next to the spaceship collection name to show the spaceship collection also in Viewport. Then press spacebar to play animation in Viewport. The instanced spaceships are moving as before, but there is one much larger unmoving spaceship in the center of the scene, and it clearly shouldn't be there. (That is the spaceship collection that we changed to visible in step 4. for Renders and in step 5. for Viewport). The point of this step 5. is that the bug is even more obvious in animation than in a single still image.
Update to the bug report:
There is still the bug that rendering with eevee and cycles produce very different results when done in Viewport and when done in the final Render image, as described above.
However, my earlier opinion that "it is the Viewport rendering is the correct and meaningful one, andRender imagerendering is wrong" now seems false. It is likely to be the other way around: Viewport rendering is wrong and Render image rendering is doing the right thing. Why? Because there is indeed another way of hiding a collection from Viewport and from Render image rendering: The check box next to the collection name, titled "Exclude from View Layer". The whole purpose of this check box is to hide the collection, and it is already doing it.
So I would suggest just fixing Viewport rendering so that it's behavior matches the Render image rendering. That is: In Viewport, instances of collections would check if the "Show in Viewport" for that collection is true (there is an open eye icon). If the Show in Viewport is false (icon showing a closed eyelid) , then the instances of that collection would not be shown in Viewport.
Not sure which behavior is correct.
If I use Object instead of the collection in node tree, object shows up in final render even if it's disabled from viewport and render.
but that's not the case for collection. So I think collection should also be visible in final render.
Same issue is also discussed in #97535 (Source Collection visbility will affect the final render of the links object(geo nodes) in eevee/cycles)
So I'll merge this report in
#97535
.Don't hesitate to comment if there is any sort of misunderstanding. Thanks again for the report
Closed as duplicate of #97535
