Slow initialization in the rendered viewport after the default normal map added #97378
Reference: blender/blender#97378
Graphics card: Quadro RTX 3000 with Max-Q Design/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
slow initialization time in viewport rendering.mp4
The slow initialization in the rendered viewport occurs after the default normal map node was added in the Skin shader. (The Skin shader is very simple - it contains just a Principled BSDF and Material Output.) I have tried both CUDA and Optix, and the slow initialization exists in both cases after the default normal map node added.
Sample to test slow initialization in viewport rendering.blend
Steps to reproduce the bug:
1, Download the sample file and open Blender;
2, Select the mesh, and go to the Sculpting mode, and then under the "Remesh" tab change the Voxel Size from 0.4 m to 0.004 m, or even smaller value if your computer can handle. Click "Remesh".
3, Then click the rendered preview. You will find that the higher the poly-count, the slower initialization speed.
4, Go to the Shading mode, and remove the Normal Map, and click the rendered preview. Your initialization speed returns to normal, even if the poly-count is high.
Added subscriber: @Stay_Here
Added subscriber: @LukasStockner
If the issue can't be reproduced with another file, here are some things you can check to narrow it down a bit:
The task has been updated, and a sample file has been uploaded and the steps to reproduce the bug are included.
This problem has something to do with the poly-count of the mesh.
To answer your questions:
Thank you!
Thanks for the info!
Turns out that the slowdown is the tangent space computation. The reason for the slowdown when adding the node is that the Normal Map node requires tangents to operate. In an F12 render, the shader graph would be optimized, and the unconnected node would be removed. However, for viewport renders, this optimization is not performed. This is on purpose: Otherwise, you'd end up in a situation where e.g. changing a mix factor from 0 to 0.1 would trigger a complete rebuild since a branch of the shader just "came alive". Therefore, interactiveness is prioritized over startup time.
You can verify this by connecting the Normal Map node to the shader: Now an F12 render also takes longer.
I've added some optimizations in D14675 to speed this up a bit, but some level of slowdown is expected here unfortunately.
Thank you for your explanation!
In the sample file, after remeshing the cube with the voxel size from 0.4 m to 0.004 m to get 1.5 M vertices, my render result after pressing F12 is:
Unconnecting the Normal Map node: 10.10 s
Connecting the Normal Map node to the Normal on Principled BSDF: 18.01 s
Thanks again!
