Truncation Error for Integers Capture on Points after Resampling #97761
Closed
opened 2022-05-02 02:19:24 +02:00 by Spoolofwhool · 10 comments
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-04-30 21:56, hash: 12217714c7
Worked: Unknown, doesn't work in 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: 'cc66d1020c3b'
In Geometry Nodes, for some int or float values (ex. 15), if they're captured in the points of a curve using Capture Attribute node then the curve is resampled, truncation error can result in some of the resampled points returning a value of one less than was captured if the value is cast to an integer data type at some point in the node tree.
  1. Create a new Geometry Node tree
  2. Add a Curve Line node.
  3. Connect the Curve output of the Curve Line node from Step 2 to a new Capture Attribute node.
  4. Set the Capture Attribute node from Step 3 to Integer / Point / 15.
  5. Connect the Geometry output of the Capture Attribute node from Step 3 to a new Resample Curve Node.
  6. Set the Resample Curve node from Step 5 to Count / 32 (The number of resampled points needs to be sufficiently high as the trunaction error appears to be random depending on the number of resampled points).
  7. Connect the Curve output of the Resample Curve node from Step 5 and the Attribute output of the Capture Attribute node from Step 3 to the Viewer node and view the Control Points values of the viewer in the Spreadsheet window. Some of the values will be 14, which is incorrect as they should all be 15.
    Optionally: A Compare node set to Integer / Equal / 15 with A connected to the Attribute output of the Capture Attribute node can be introduced to demonstrate that it isn't a Viewer Node/Spreadsheet Error.Bug_ResampleTruncation.blend
**System Information** Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71 **Blender Version** Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-04-30 21:56, hash: `12217714c7` Worked: Unknown, doesn't work in 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: 'cc66d1020c3b' **Short description of error** In Geometry Nodes, for some int or float values (ex. 15), if they're captured in the points of a curve using Capture Attribute node then the curve is resampled, truncation error can result in some of the resampled points returning a value of one less than was captured if the value is cast to an integer data type at some point in the node tree. **Exact steps for others to reproduce the error** 1. Create a new Geometry Node tree 2. Add a Curve Line node. 3. Connect the Curve output of the Curve Line node from Step 2 to a new Capture Attribute node. 4. Set the Capture Attribute node from Step 3 to Integer / Point / 15. 5. Connect the Geometry output of the Capture Attribute node from Step 3 to a new Resample Curve Node. 6. Set the Resample Curve node from Step 5 to Count / 32 (The number of resampled points needs to be sufficiently high as the trunaction error appears to be random depending on the number of resampled points). 7. Connect the Curve output of the Resample Curve node from Step 5 and the Attribute output of the Capture Attribute node from Step 3 to the Viewer node and view the Control Points values of the viewer in the Spreadsheet window. Some of the values will be 14, which is incorrect as they should all be 15. Optionally: A Compare node set to Integer / Equal / 15 with A connected to the Attribute output of the Capture Attribute node can be introduced to demonstrate that it isn't a Viewer Node/Spreadsheet Error.[Bug_ResampleTruncation.blend](https://archive.blender.org/developer/F13044447/Bug_ResampleTruncation.blend) ![Screenshot_375.png](https://archive.blender.org/developer/F13044450/Screenshot_375.png) ![Screenshot_374.png](https://archive.blender.org/developer/F13044449/Screenshot_374.png)
Author
Added subscriber: @Spoolofwhool
#97928 was marked as duplicate of this issue
Member
Member
Member
Added subscriber: @Greywolf
Member
This is probably a floating point precision issue.
I've also merged other similar report. Feel free to reopen if they are not same.
This is probably a floating point precision issue. I've also merged other similar report. Feel free to reopen if they are not same.
Added subscriber: @dfelinto
Legit bug. Even if you switch the Attribute type to float you see this happening (set a row filter in the spreadsheet editor to show only below 15.000 rows).
This issue was referenced by 2e70af5cd5
This issue was referenced by 2e70af5cd527e2c1f40e6f3af22adc3337714744
Member
Jacques Lucke self-assigned this 2022-05-18 17:03:09 +02:00
5 Participants
Reference: blender/blender#97761
