Concave cutter causes bevel with arc outer miter to produce weird geo with protrusions inside the negative space of the cutter #98035
Reference: blender/blender#98035
Operating system: Manjaro Linux
Graphics card: NVIDIA GeForce GTX 1060 6GB
Broken: 3.1.2
Worked: 2.79.0
Create a mesh and give it a concave wall (i.e. a cylinder with 6 sides, subdivide one face from top to bottom, and move it in towards the center on the x and y axes), and create a difference boolean on the top of the default cube and hide the cutter. Next, grab a cylinder a decent number of sides (32 is fine), and create a union boolean inside the negative space of the cut. Finally, add a bevel modifier to the cube, set the Miter Outer setting under Geometry to Arc, and you should see geo similar to as shown in the screenshot below.
The bottom surface of the cutter is completely flat, however rotations of the complete surface does not affect the bug. There is a workaround to prevent the weird geo by performing separate bevels before and after the protrusion boolean.
Here is a sample blend file demonstrating the bug using the instructions above:
sample.blend
Added subscriber: @JedSwamp43
Added subscribers: @HDMaster84, @howardt, @lichtwerk
CC @howardt
CC @HDMaster84
One thing I just noticed now is that this is affected by the 'Loop Slide' bevel option. by default this is turned on and is what causes this bad geo. turning off loop slide will fix this problem.
