Regression: keymap 2.7x: Right click does not select nodes #98370
5 Participants
Reference: blender/blender#98370
Operating system: win10 64
Graphics card: 1050 ti
Caused by
4c3e91e5f5
I'm using keymap 2.7x (right click select) in both shift-select is not selecting nodes in recent 3.2.0 builds.
This only occurs when selection mode is set to Tweak
Added subscriber: @SergeL
Added subscriber: @mano-wii
I'm having trouble understanding the problem.
Did you try to deselect with RMB and cursor over node?
With the cursor over no node everything is deselected as expected.
I tested it on 2.79 and the behavior is consistent.
Please try to Load Factory Settings (File → Defaults → Load Factory Settings), then enable the keymap 2.7x (right click select) and see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Problem is still here and yes cursor should be over node. Please, look at original post, I've added more info.
Added subscriber: @ideasman42
Okay, I can confirm now. It is a regression introduced in {4c3e91e5f565b81dd79b5d42f55be5b93662d410}
Cc. @ideasman42
Right click selection inconsistent with nodesto Regression: keymap 2.7x: Right click does not deselect the other nodes@SergeL I can't redo the problem, can you check if this was fixed by
790fe55c52
?Changed status from 'Confirmed' to: 'Needs User Info'
@ideasman42 I tested latest daily build and issue with deselection disappeared, but shift-selecting with Tweak mode is not working.
You can check it by yourself: enable Tweak in T-panel, deselect all nodes, press shift and do right clicking on node's header -> nothing happens. Other selection modes inT-panel work fine though.
Regression: keymap 2.7x: Right click does not deselect the other nodesto Regression: keymap 2.7x: Right click does not select nodesChanged status from 'Needs User Info' to: 'Confirmed'
This impacts the default key-map too, looked into this will commit a fix tomorrow.
This issue was referenced by
e0f3c23ac0
