Certain operators (relying on context region) crash when called with INVOKE_AREA
/ EXEC_AREA
#98491
5 Participants
Reference: blender/blender#98491
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.2.0 Beta, branch: master, commit date: 2022-05-26 13:12, hash:
bf53956914
Worked: --
Short description of the error
INVOKE_AREA
/EXEC_AREA
Steps to reproduce
execute this in blenders python console
So the reason for the crash is that an operator is invoked with INVOKE_AREA here (it does not crash with INVOKE_DEFAULT or any other Execution Context -- except for EXEC_AREA, same thing applies for that one, see below)
If
INVOKE_AREA
orEXEC_AREA
is used, the region gets removed from context, seeOperators relying on / using region (e.g. via CTX_wm_region) can easily crash then.
Of course we could guard against this with a simple check (and this is done in a couple of places), not sure though if this is the smartest thing to do -- since there are many, many operators that would need the extra treatment...)
Original report
This script is use to check the active material, it can be run correct in the main window, but not popup window(change the pref window to node editor)
#98491.blend
Added subscriber: @1029910278
Added subscriber: @lichtwerk
I am getting the wrong context, but no crash.
To avoid the context error, I think you need to set the nodetree explicitly?
So:
This comment was removed by @1029910278
setting the node tree will be directly crash
area.spaces- [x].node_tree = bpy.context.object.active_material.node_tree
test1.crash.txt
previous crash
blender.crash.txt
bpy.ops.node.view_all
is invoked withINVOKE_AREA
here (it does not crash withINVOKE_DEFAULT
or any other Execution Context -- except forEXEC_AREA
, same thing applies for that one, see below)@1029910278 : is there any particular reason you are using
INVOKE_AREA
here?If
INVOKE_AREA
orEXEC_AREA
CTX_wm_region
) cn easily crash then.Of course we could guard against this with a simple check (and this is done in a couple of places), not sure though if this is the smartest thing to do -- since there are many, many operators that would need the extra treatment...)
popup window call operator will crash blenderto Certain operators (relying on context region) crash when called with `INVOKE_AREA` / `EXEC_AREA`Will raise prio (for @ideasman42 to consider lowering again) since it is a crasher
Probably these should just not exist, I can't think of a good purpose for them. They could probably be made to behave like
EXEC_REGION_WIN
andINVOKE_REGION_WIN
and deprecated. But someone needs to check the few places we do use them and see if that change would cause any problems.Even if
INVOKE_AREA
/EXEC_AREA
are removed, the crashes will still exist since it's possible for the context's region to be null.Another issue is the region might be set but not the desired type, so an operator may expect the window region but have a toolbar region, while it might not crash it's not going to work properly.
So AFAICS the operators poll function or the operators internal logic should be fixed either way.
