Regression: Tweak mode broken #98615
Closed
opened 2022-06-05 18:27:54 +02:00 by Christopher Tyler · 9 comments
Operating system:
Graphics card:
Broken: 3.2 build Downloaded June 4th
Worked: 3.1.2 release
In 3.1.2, Tweak mode was used to directly grab an element and operate on it with a given tool. For instance, Edge Slide. In Tweak mode you can grab the selected edge (or loop) and directly slide it without needing to use the widget (which is often way off screen).
In 3.2, Tweak mode always just moves the selected elements.
Here are two videos examples.
  • Open default scene
  • In edit mode -> select bevel tool (or any other)
  • Change to face selection mode
  • Change drag mode to tweak
  • Click and drag over any face
video files:
3.1.2 https://drive.google.com/file/d/1cK2StB721gIN4wNr5DRw7yKhoFSq2ux3/view?usp=sharing
3.2 https://drive.google.com/file/d/1EOxL__KEZAqW5XDllafFCF4JgOmJ5bXU/view?usp=sharing
**System Information** Operating system: Graphics card: **Blender Version** Broken: 3.2 build Downloaded June 4th Worked: 3.1.2 release **Short description of error** In 3.1.2, Tweak mode was used to directly grab an element and operate on it with a given tool. For instance, Edge Slide. In Tweak mode you can grab the selected edge (or loop) and directly slide it without needing to use the widget (which is often way off screen). In 3.2, Tweak mode always just moves the selected elements. **Exact steps for others to reproduce the error** Here are two videos examples. - Open default scene - In edit mode -> select bevel tool (or any other) - Change to face selection mode - Change drag mode to tweak - Click and drag over any face video files: | 3.1.2 | https://drive.google.com/file/d/1cK2StB721gIN4wNr5DRw7yKhoFSq2ux3/view?usp=sharing | | -- | -- | | 3.2 | https://drive.google.com/file/d/1EOxL__KEZAqW5XDllafFCF4JgOmJ5bXU/view?usp=sharing |
Added subscriber: @Christopher-Tyler
Member
Member
Member
Thanks for the report. I can confirm.
Bisecting...
Thanks for the report. I can confirm. Bisecting...
Pratik Borhade changed title from Tweak mode broken in 3.2 to Regression: Tweak mode broken 2022-06-06 05:15:03 +02:00
Member
Changed status from 'Confirmed' to: 'Needs Developer To Reproduce'
Member
Added subscriber: @ideasman42
Member
This behavior is probably expected as Campbell said in #96885
In #96885#1351460, @ideasman42 wrote:
Drag is now translating, not rotating - which is expected as tweak's drag action is to translate.
BTW this is caused by 0f530b0b03
@ideasman42 hi, could you take a look at this report?
Is it fair to merge this ticket in #96885
This behavior is probably expected as Campbell said in #96885 > In #96885#1351460, @ideasman42 wrote: > Drag is now translating, not rotating - which is expected as tweak's drag action is to translate. BTW this is caused by 0f530b0b03 @ideasman42 hi, could you take a look at this report? Is it fair to merge this ticket in `#96885`
I downloaded the 3.2.1 version, and Tweak is still broken. It only moves instead of using the current tool. For instance, Edge Slide, when I try and use Tweak mode it just moves the selected edges instead of sliding them. This is a big problem. It worked correctly in 3.1.
Closed as duplicate of #96885
Reference: blender/blender#98615
