PLY exporter do not export the selected vertex colors attribute #98870
Open
opened 2022-06-14 03:59:56 +02:00 by Fangyang Shen · 6 comments
Operating system: Ubuntu 22.04
Graphics card: Nvidia GTX 1050
Broken: 3.2.0 stable
Worked: 3.1.2 stable
When you have multiple Vertex Colors attributes/layers for a mesh, the PLY exporter used to export the selected/highlighted one as Vertex Colors.
In 3.2.0 the exporter just exports the first Vertex Colors in alphabetic order regardless which one you choose.
vc12.blend
Try export the mesh "Grid" with different Vertex Colors layers.
**System Information** Operating system: Ubuntu 22.04 Graphics card: Nvidia GTX 1050 **Blender Version** Broken: 3.2.0 stable Worked: 3.1.2 stable **Short description of error** When you have multiple Vertex Colors attributes/layers for a mesh, the PLY exporter used to export the selected/highlighted one as Vertex Colors. In 3.2.0 the exporter just exports the first Vertex Colors in alphabetic order regardless which one you choose. **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). [vc12.blend](https://archive.blender.org/developer/F13159589/vc12.blend) Try export the mesh "Grid" with different Vertex Colors layers.
Author
Added subscriber: @shenfy
Added subscriber: @ideasman42
[D14718: Fix blender/blender#89017: PLY files from various programs are incompatible due to their exporters, and vertex-colored point clouds do not import color.](https://archive.blender.org/developer/D14718) should resolve this report.
Member
Member
Member
I'm able to replicate.
D14718 should resolve this report.
We should probably also mention this task there in patch If D14718 also fixes this
I'm able to replicate. > [D14718](https://archive.blender.org/developer/D14718) should resolve this report. We should probably also mention this task there in patch If [D14718](https://archive.blender.org/developer/D14718) also fixes this
Reference: blender/blender-addons#98870
