GPU renders incorrectly cycles scene #98895
Reference: blender/blender#98895
Operating system:Windows 11 21H2
Graphics card:RX 6600M
CPU: Ryzen 7 5800H
RAM: 16GB 3200MHz
Broken: 3.2
When using only the GPU to render the scene, it renders either incorrectly or as seen on the picture, it renders only the normals but when using the CPU, it renders correctly with no issues, I'm using HIP to render the scene
Shotgun_Test2_1.blend
Added subscriber: @User19
Added subscriber: @Alaska
Are you able to provide us with the .blend file so we can investigate the issue?
Also, since HIP on Windows is relatively new in both GPU driver support, SDK support, and Cycles support, you may be able to fix this issue by updating your GPU driver.
This comment was removed by @User19
I'm using the latest AMD Drivers{F13208485}
I personally can not reproduce the issue in CUDA or OptiX on Linux with a RTX 3060. As such I assume this is an issue only when using HIP. CC @ThomasDinges to take a look at this report as you have a AMD GPU?
One other thing I should note is that many of the materials have a
Shader to RGB
node in the node tree. This is not properly support in Cycles and may be causing some issues.Renders correct here, both in 3.2 and 3.3 Alpha with AMD Radeon 5500 XT and HIP.
@User19 hi, can you still replicate this issue?
Please upload system info file: {nav Help > Save System Info}
