Regression: location override ignored when used in a shadertree (Texture Coordinates node, object coordinates) #99272
7 Participants
Reference: blender/blender#99272
Operating system: Windows 11
Graphics card: RTX 2060 mobile
Broken: 3.2.0, Caused by {1695d38989fd482d3c010dc9ba4b0cb8e07a7139}
Worked: 3.1.2
It seems the location override does not ripple down into the usage of the location in the
Texture Coordinate
object coordinates.Its coordinates are fine in the 3DView though.
Here is a simplified example:
#99272.zip
lib.blend
with an empty that controls a gradient position on a plane viaTexture Coordinate
object coordinatesmain_override.blend
with the collection fromlib.blend
linked, and the location of the empty overriden.expected:
observed:
Original report
The shading setup made in 3.1.2 yields an unexpected result in 3.2.0 and higher.
3.2.0_Result
3.2.1_Release_Candidate
3.1.2_CORRECT_VERSION
PROJECT.zip
Added subscriber: @Jalmaries
Added subscriber: @mano-wii
I can confirm the problem.
Apparently the nodes in the linked material that return the position of Empties are not returning the correct position.
Certainly the file can be simplified further (I tried but for some reason the objects returned after reloading the file).
I'm investigating to find where the problem was introduced.
Added subscriber: @mont29
{1695d38989fd482d3c010dc9ba4b0cb8e07a7139} is the first bad commit
Author: @mont29
Added subscriber: @lichtwerk
OK, it seems the location override does not ripple down into the usage of the location in the
Texture Coordinate
#99272.zip
lib.blend
linked, and the location of the empty overriden.Errors after updating from 3.1.2 to 3.2.0to Regression: location override ignored when used in a shadertree (Texture Coordinates node, object coordinates)This issue was referenced by
7f24d90f11
Added subscriber: @noc2
You guys marked this as "Fixed" yet the bug persists. What gives???????
EDIT: Just found out now that the shader tree setup in the source library works as expected only if it is linked to the main scene from scratch and the scene file is saved. Yet, the result is as before when the original scene file is opened in 3.2.1 So, the whole scene needs to be assembled from scratch in this case??
This comment was removed by @Jalmaries
Tested the scene on 3.2.1 and the bug is still there. Did you actually test your bug fix on the scene that I sent you before marking the bug report as fixed? Any hope linking will be fixed on this version or will we have to wait for 3.3 and higher to be able to use library linking in production work.
EDIT: The problem occurs while upgrading version, linking from start in 3.2.1 works fine. While tresspassing in versions document corrupts.
Added subscriber: @LazyDodo
Bug is currently only fixed in master, you'd have to download a nightly 3.3 build from builder.blender.org to test it.
So this didn't actually make it into 3.2.1??? What's the point of having a bug fix release if such crucial bugs are fixed solely toward a main release? You guys came up saying that 3.2's file referencing was improved. Here's a really crucial bug with file linking and it only makes it into master. I'm stumped... :( :( :(
Also as a reminder, overrides of materials remain dodgy at best, and is not officially supported so far.
