bug in bvh #99377
Closed
opened 2022-07-04 07:46:32 +02:00 by Cad Logan · 6 comments
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: Intel(R) UHD Graphics 605 Intel 4.5.0 - Build 30.0.101.1340
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: blender/blender@c77597cd0e
Addon Information
Name: BioVision Motion Capture (BVH) format (1, 0, 0)
Author: Campbell Barton
**System Information** Operating system: Windows-10-10.0.22000-SP0 64 Bits Graphics card: Intel(R) UHD Graphics 605 Intel 4.5.0 - Build 30.0.101.1340 **Blender Version** Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash: `blender/blender@c77597cd0e` Worked: (newest version of Blender that worked as expected) **Addon Information** Name: BioVision Motion Capture (BVH) format (1, 0, 0) Author: Campbell Barton **Short description of error** [Please fill out a short description of the error here] **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)]
Author
Added subscriber: @cad511
#99378 was marked as duplicate of this issue
#99379 was marked as duplicate of this issue
Member
Member
Member
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
This report does not contain all the requested information, which is required for us to investigate the issue. Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem. A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Reference: blender/blender-addons#99377
