The values of the diffuse direct and indirect passes are pre-multiplied with the diffuse colour making it impossible to swap textures in post. #100056
2 Participants
Reference: blender/blender#100056
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-27 22:46, hash:
7a44f62bdb
As in other render engines, Cycles has separate diffuse lighting (direct/indirect) and diffuse colour passes. Unlike other engines however, cycles is altering the value of the lighting passes based on the colour of the texture. For example if the texture has black elements, then the diffuse direct and indirect passes are darkened in the same areas. In other engines the lighting passes are not affected at all by the value of the underlying texture, because this makes it impossible to perform the most basic of compositing tasks. The RS manual has a great explanation as to why this is important and how the image is recombined from the passes (basically the same as cycles regarding recombining of the raw (rs version of direct/indirect) and filter (rs version of colour pass). Check the integrated aov section of their manual, in particular the raw/filter workflow to see how the passes need to look.
To see how serious of an issue this is, open up the below blend file, which demonstrate how even the most common compositing task is unachievable as a result of the contamination. Firstly head to the compositor, and hit render. The node tree replaces the diffuse colour with a new texture, but because the texture data has affected the lighting passes, the brick material on the right hand side monkey is still evident. The material on the other monkeys doesn't have a texture connected to the base colour of the principled BSDF, so this works correctly.
An example of a situation in which this is important: You've just rendered a 3 week animation and the clients asks you to change the marble texture that appears throughout. Without the ability to swap out the texture in post, it's necessary to re-render the entire animation again. Even if using collections to mask out all but the floor, it's still a major nightmare.
diffuse passes bug.blend
Added subscriber: @3di
Added subscriber: @brecht
Supporting texture replacement is not a goal of the render passes implementation. The design choice was to optimize render times as much as possible, which means not computing lighting for cases where the texture is black.
Thanks. Might it be possible to make this optimisation optional? For large animations rendering a bit slower is a good trade-off if it means you can potentially avoid rendering twice.
Even Alex Honnold uses ropes when he thinks it might get windy.
I don't think it's practical, it probably requires deep compositing and conflicts with OSL design of optimizing out zero weight closures.
It's not even clear to me that Cycles is unlike other renderers here. From the Redshift examples I'm guessing they do the same as Cycles, you can see the texture color affect the lighting pass near edges and DoF where it's difficult to cleanly separate them. And at least when I worked on Arnold it was no different either.
Thanks. This image explains better (pay attention to how the diffuse raw pass is purely lighting , the textures data is limited only to the diffuse filter pass): https://docs.redshift3d.com/display/RSDOCS/Integrated+AOVs#IntegratedAOVs-DiffuseLighting:~:text=set%20to%200-,Raw,-Shading%20Elements
The important part is:
I get it's cool to speed up rendering by using the value of the textures to act as clamping though 👍
That sentence doesn't say anything about black elements in the texture, I guess you are assuming they can be replaced in other renderers without having actually verified if that's true.
Either way, this behavior is very unlikely to change in Cycles, so not really worth discussing.
The image shows that the black areas of the textures aren't affecting the diffuse lighting passes. I have verified it's true, I wrote a multipass denoiser for redshift in houdini a few years ago.
No worries though, thanks for taking the time to respond.
Ok, maybe the example from that documentation was not ideal since it seemingly has no black pixels in the diffuse filter AOV (besides the background), only near black. Or perhaps the hack is to add a tiny bit off diffuse to everything even when the texture is black.
Oh, are you saying that only completely black pixels in the colour pass lead to contamination of the direct and indirect lighting passes?
just checked and non blacks are also causing contamination:
On close inspection, it actually appears to be introducing noise to just the areas of the lighting passes where the colour data is present. The rest of the pass is completely clean.
even when the darkest brick texture component is set to a dark gray, it's still introducing the contamination:
You can see the same effect in Redshift (but more subtle), the darker areas of the texture have more noisy lighting. That's the result of importance sampling and Russian roulette allocating fewer samples to such dark areas.
Naa, that's because it's a transmissive surface so is getting less diffuse samples. Check the black pip on the lemon, and also the black parts of the wood texture. Not even the slightest introduction of texture colour/value or noise on the light passes.
