Regression: UI freeze for Render Animation AND changing frame being previewed #100074
Closed
opened 2022-07-30 01:35:43 +02:00 by Ellen Dash · 14 comments
(NOTE: I am opening this on behalf of someone else, since I have a developer.blender.org account and she doesn't.)
Operating system: Manjaro Linux
Graphics card: 2x Radeon RX 6600 (only one used for Blender renders)
Broken: 3.2.0, 3.2.1, 3.2.2, c857405c0d
Worked: 3.1.2
This was tested in 3.2.1 on Windows 10, as well, and it had the same problem.
All of these were tested with the --factory-startup flag.
  1. Open the attached LightSwitchScene.blend file.
  2. Render -> Render Animation.
  3. The first frame renders, then the Blender UI freezes.
If you choose Render -> Render Image, it works.
OR:
  2. Select a different frame. Any frame.
  3. As soon as it tries to render the preview for the newly-selected frame, the Blender UI freezes.
Notes about the file
There are two view layers. View Layer is the actual light switch, View Layer_001 is a watermark. These are composited together.
(**NOTE**: I am opening this on behalf of someone else, since I have a developer.blender.org account and she doesn't.) **System Information** Operating system: Manjaro Linux Graphics card: 2x Radeon RX 6600 (only one used for Blender renders) **Blender Version** Broken: 3.2.0, 3.2.1, 3.2.2, c857405c0d28 Worked: 3.1.2 This was tested in 3.2.1 on Windows 10, as well, and it had the same problem. All of these were tested with the `--factory-startup` flag. **Short description of error** **Exact steps for others to reproduce the error** 1. Open the attached LightSwitchScene.blend file. 2. Render -> Render Animation. 3. The first frame renders, then the Blender UI freezes. If you choose Render -> Render Image, it works. OR: 1. Open the attached LightSwitchScene.blend file. 2. Select a different frame. Any frame. 3. As soon as it tries to render the preview for the newly-selected frame, the Blender UI freezes. **Notes about the file** There are two view layers. `View Layer` is the actual light switch, `View Layer_001` is a watermark. These are composited together. [LightSwitchScene.blend](https://archive.blender.org/developer/F13326008/LightSwitchScene.blend)
Author
Added subscriber: @duckinator
Member
Member
Member
Thanks for the report. In 3.2 and above version UI did not freeze instead rendering stuck at first frame is what I noticed.
While final render animation works in 3.1. I'll search for the affecting commit.
Thanks for the report. In 3.2 and above version UI did not freeze instead rendering stuck at first frame is what I noticed. While final render animation works in 3.1. I'll search for the affecting commit.
Member
Tried to bisect between 52a5f6856268 - e5a738af6d51 and pointed me to 8399375098 (I don't think this commit is responsible)
Tried to bisect between `52a5f6856268` - `e5a738af6d51` and pointed me to 8399375098 (I don't think this commit is responsible)
Added subscriber: @ErickNyanduKabongo
This sounds like the same problem as in #100061
Pratik Borhade changed title from UI freeze for Render Animation AND changing frame being previewed to Regression: UI freeze for Render Animation AND changing frame being previewed 2022-08-02 08:02:30 +02:00
Member
Seems a regression so raising the priority.
Added subscribers: @neXyon, @brecht
The reason this was difficult to bisect is that what makes the difference is the ffmpeg library version. The same Blender code works with the older ffmpeg does not hang.
I verified it by temporarily restoring the old libraries like this (make update will set them to the latest again):
cd ../lib/linux_centos7_x86_64/ffmpeg
svn switch https://svn.blender.org/svnroot/bf-blender/tags/blender-3.1-release/lib/linux_centos7_x86_64/ffmpeg
Backtrace where it hangs in audaspace: P3130
CC @neXyon
The reason this was difficult to bisect is that what makes the difference is the ffmpeg library version. The same Blender code works with the older ffmpeg does not hang. I verified it by temporarily restoring the old libraries like this (`make update` will set them to the latest again): ``` cd ../lib/linux_centos7_x86_64/ffmpeg svn switch https://svn.blender.org/svnroot/bf-blender/tags/blender-3.1-release/lib/linux_centos7_x86_64/ffmpeg ``` Backtrace where it hangs in audaspace: [P3130](https://archive.blender.org/developer/P3130.txt) CC @neXyon
Proposed solution:
diff --git a/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp b/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp
index ad33c26..4ad6ff5 100644
--- a/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp
+++ b/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp
@@ -363,8 +363,10 @@ int FFMPEGReader::read_packet(void* opaque, uint8_t* buf, int buf_size)
        long long size = std::min(static_cast<long long>(buf_size), reader->m_membuffer->getSize() - reader->m_membufferpos);
+       if(size == 0)
+               return AVERROR_EOF;
        if(size < 0)
-               return -1;
+               return AVERROR(EIO);
        std::memcpy(buf, ((data_t*)reader->m_membuffer->getBuffer()) + reader->m_membufferpos, size);
        reader->m_membufferpos += size;
Based on what one ffmpeg's own tools does:
https://github.com/FFmpeg/FFmpeg/blob/master/tools/target_dem_fuzzer.c#L50
Proposed solution: ``` diff --git a/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp b/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp index ad33c26..4ad6ff5 100644 --- a/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp +++ b/extern/audaspace/plugins/ffmpeg/FFMPEGReader.cpp @@ -363,8 +363,10 @@ int FFMPEGReader::read_packet(void* opaque, uint8_t* buf, int buf_size) long long size = std::min(static_cast<long long>(buf_size), reader->m_membuffer->getSize() - reader->m_membufferpos); + if(size == 0) + return AVERROR_EOF; if(size < 0) - return -1; + return AVERROR(EIO); std::memcpy(buf, ((data_t*)reader->m_membuffer->getBuffer()) + reader->m_membufferpos, size); reader->m_membufferpos += size; ``` Based on what one ffmpeg's own tools does: https://github.com/FFmpeg/FFmpeg/blob/master/tools/target_dem_fuzzer.c#L50
Member
Joerg Mueller self-assigned this 2022-08-05 19:34:56 +02:00
Member
This has already been fixed with e4fd2d5754
Ok, this fix should have been committed to blender-v3.3-release, I will backport it.
Ok, this fix should have been committed to `blender-v3.3-release`, I will backport it.
5 Participants
Reference: blender/blender#100074
