Geometry Node: New Sample Curve #100121
1 Participants
Reference: blender/blender#100121
Adding support for a random attribute to the sampling node exposed the problem of attribute evaluation ignoring the calculated curve. This design variant is intended to treat the sampling of values from calculated curves as a new attribute-based сontext.
Example: sampling a random vector from curve points. You want the vector to keep its length. But even the original implementation of normals kept the length just because of the normalization. Nonlinear interpolation in spline space for a vector has the ability to rotate it without loss of length and incorrect deformations.
Or you want to sample a color. You can set the color for the breakpoints and... Whoa, those are just linear transitions! Handles cannot be used. They are not a domain and this design does not violate that. Simply by sampling an attribute, you can sample it not only from breakpoints, but from handles!
Also, in addition to entering an attribute as the domain of the sampled curve, a segment data node is offered. This low-level node is for primary access to cache data. The sampled attribute input node uses this as its signature. But it can also be useful for the user to be able to use this data, for example, to visualize the operation of a bezier curve.
When sampling, 3 types of values must be present in the scope of the context:
Also sampling features:
Curve Input:
Changed Nodes:
Position:
Normal:
Curve Tangent:
Index:
ID:
Spline Length, Parameter, Resolution, Cyclic:
Context Add:
Add Nodes (Valid only in SampleCurveContext):
First test version: https://developer.blender.org/P3114
Added subscriber: @mod_moder
