Scene not changed when use Python in Pinned workspace #100165
Reference: blender/blender#100165
Failed: Version 3.3.0 Beta 31/07/2022
Worked: Never, PIN is a new option in 3.3 version.
Using the add-on we have developed for storyboarding, when the scene is pinned to the workspace, the scene is not correct when is changed using python.
WorkspacePinned.mp4
The python code is very simple:
Added subscriber: @antoniov
Added subscribers: @JulianEisel, @mendio
Added subscriber: @OmarEmaraDev
I can't seem to replicate this myself. Does the target Workspace have a different pinned scene than
03_Scene
?I am testing with this file:
pinnedWorkspace.blend
What does this mean?
Are you able to reproduce the issue on the attached file? Because I can't seem to be able to.
No, I cannot...I guess this is related to some multi thread issue and depends on the file size and complexity and CPU speed.... a really hard bug to catch.
Could you share the file where you originally reproduced the bug?
I'm doing some debug and I have seen something weird.
My python code does this:
context.window.workspace = scene.storypencil_edit_workspace
After that line, both variables would contain the same, I mean, the right variable is a workspace and is assigned to the
context.workspace
, but doing a debug I can see the left variable is not updated as you can see in the image below stopped in the next line after the assign of the value.Is this normal? the question is why the variable is not updated because the code is working when is not pinned, so that means that the
update is delayed.How can I force to update that value?
Added subscriber: @storyvalk
It seems this is normal. Changing the workspace is a change of context, so it is intentionally delayed until all code that depends on the current context is executed.
This is done by adding a
ND_WORKSPACE_SET
notifier to the window, which is handled inwm_event_do_notifiers
, which execute automatically as part of the main loop and can't be invoked manually as far as I can see.So you can't force an update to that value. Why do you need it to take effect immediately?
About that, see D15614: Py Docs: Document delayed setting of UI data.
@OmarEmaraDev I need the instant update because the add-on is switching all the time back and forth between VSE scene and strip scene to draw the storyboard.... I will investigate alternatives. Anyway, it would be great to have a
context.windows.workspace.update()
for this type of situations as we have forview_layers
. I know that force the update is not the best, but in situations like this could be the best solution.The situation is a bit different for view layers. For them the update is just delayed for performance reasons. So enforcing an immediate update is fine. For workspaces (and other UI changes) it's delayed because it could corrupt context. IIRC switching workspaces immediately will just result in crashes in many cases.
Since this is getting documented as Julian pointed out, I would say this is handled.
But is the original issue you pointed out a manifestation of the issue you just described? Or is it different?
I all agree, we could consider this a
