Job Storage Path in add-on should be platform-dependent #100196
Closed
opened 2022-08-04 11:27:08 +02:00 by Sybren A. Stüvel · 10 comments
The getConfiguration OpenAPI operation currently returns the configuration of the Manager as-is. This is insufficient for cross-platform installations, though, as a Manager running Linux will report a Linux path even when the client is running Windows.
This is also reflected in the job storage path as reported by the Blender add-on.
Adding platform and audience parameters like the getVariables operation would resolve this. Those can then be used by the API implementation to perform path modification on the job storage path before returning it.
The `getConfiguration` OpenAPI operation currently returns the configuration of the Manager as-is. This is insufficient for cross-platform installations, though, as a Manager running Linux will report a Linux path even when the client is running Windows. This is also reflected in the *job storage path* as reported by the Blender add-on. Adding `platform` and `audience` parameters like the `getVariables` operation would resolve this. Those can then be used by the API implementation to perform path modification on the job storage path before returning it.
Author
Owner
Author
Owner
Added subscriber: @dr.sybren
Added subscriber: @WouterVandenneucker
Came here to write exactly this :)
We've got a threadripper render server with another node on the way running Linux and designer workstations are on windows.
Flamenco 3 being able to run on both would mean I can ditch our self written -far from perfect- render manager that isn't really flexible on adding new devices.
Is there a manual workaround right now using the flamenco-worker.yaml file? There is nothing on changing the shared storage location or file path 'type' in the docs
Came here to write exactly this :) We've got a threadripper render server with another node on the way running Linux and designer workstations are on windows. Flamenco 3 being able to run on both would mean I can ditch our self written -far from perfect- render manager that isn't really flexible on adding new devices. Is there a manual workaround right now using the `flamenco-worker.yaml` file? There is nothing on changing the shared storage location or file path 'type' in the docs
Added subscriber: @gabe2252
Added subscriber: @zuggamasta
We're currently working on our files from Apple Macbooks, and rendering on Windows (could be linux) machines. Sadly flamenco3 is also not able to support us here. And I still did not set up an automation for our case. (Still betting on flamenco getting cross plattform love)
Author
Owner
This is definitely something that should be supported. The two-way variables will help with this: https://flamenco.blender.org/usage/variables/multi-platform/
There's nothing to do on your side @WouterVandenneucker, this is something that simply has to be coded into Flamenco. I'll see if I can get that done today, before I release the 2nd beta version.
This is definitely something that should be supported. The two-way variables will help with this: https://flamenco.blender.org/usage/variables/multi-platform/ There's nothing to do on your side @WouterVandenneucker, this is something that simply has to be coded into Flamenco. I'll see if I can get that done today, before I release the 2nd beta version.
This issue was referenced by 31cf0a4ecc
This issue was referenced by 31cf0a4ecc75db127877218af449610ce9d8df1c
Author
Owner
Sybren A. Stüvel self-assigned this 2022-08-31 12:06:49 +02:00
5 Participants
Reference: studio/flamenco#100196
