Geometry node - setting lacunarity to 0 crashes Blender (musgrave texture) [fine in 4.1, request to ackport] #100838
5 Participants
Reference: blender/blender#100838
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.93
Broken: version: 3.2.2, branch: master, commit date: 2022-08-02 18:15, hash:
bcfdb14560
In a fairly simple geonode tree, trying to set lacunarity to 0 will crash Blender instantly.
Geonode attribute.blend
Added subscriber: @Deehn
Added subscriber: @deadpin
Confirmed and the crash seems to be coming a bit downstream from Musgrave, the Attribute transfer node is having difficulty with that incoming data:
Oddly enough, if you unplug the Geometry input to that Attribute Transfer (down in the FENCE frame) and re-plug it, things seem fine...
Odd indeed. Thanks for confirming it :)
Added subscriber: @CharlieJolly
This seems to be fine in 4.1 beta
Can confirm it is still an issue in 3.6 and 3.3 LTS (getting NANs for z position there...)
@CharlieJolly : are you aware of a commit that fixed this? Can this be backported?
Geometry node - setting lacunarity to 0 crashes Blender (musgrave texture)to Geometry node - setting lacunarity to 0 crashes Blender (musgrave texture) [fine in 4.1, request to ackport]I believe this was fixed in #111187 when Musgrave was merged into the Noise texture or these patches.
Fix #112180: Noise with high detail and lacunarity outputs erratic values
Fix #112180. #112962
So this cannot be backported, right?
I discussed bug a while back with @Hoshinova and it was included in #111187
So it is
d98005da5d
to be backported?You probably have more overview/insight, could you just add the relevant commits to #109399 if appropriate?
@lichtwerk
d98005da5d
fixes the NAN problem, but only partially. Basically befored98005da5d
you'd get NANs for both very low and very high Lacunarity values.d98005da5d
fixes the problem for very high Lacunarity values.However this bug report mentions "trying to set lacunarity to 0 will crash Blender instantly.", so thats the case of very low Lacunarity values.
#111187 then fixed the problem for very low Lacunarity values by eliminating the Musgrave node and any buggy code with it.
The buggy code in question would be
6481bf32b3/intern/cycles/kernel/svm/musgrave.h (L375)
where 'float pwHL = powf(lacunarity, -H);' leads an high value outside the representable floating point range for very low Lacunarity values.Since this bug is caused by the way Musgrave handles Roughness it can't be fixed.
That is about it for the NAN values. As for why it crashes, I have no ideas, might be related to the NAN values.
But regardless of that
d98005da5d
should be backported.Also, since the Musgrave node doesn't exist anymore from 4.1 onward this issue could be seen as resolved.
I think this could be backported but I don't have a build system at the moment to test and recommend the backport.
