Blender 3.2.1 - Animation on nodes gets bugged out when dealing with Node Groups (duplicate node names) #101109
Closed
opened 2022-09-16 02:59:22 +02:00 by Carlo Andreacchio · 16 comments
Operating system: Ubuntu 21.04
Graphics card: GTX 1080
Broken: 3.2.1
Worked: 2.79
Animation on a node, that then gets put into a node group, effects other nodes later on
  1. Open attached blend file
  2. Make sure you have blender 2.79 hotkeys otherwise i dont know if this will work 100%
  3. in the material editor, press ctrl g to add it to a node group
  4. press tab to exit out
  5. shift a -> c -> m (add mix node)
  6. drop it between the node group and the hue sat value node
  7. scrub the timeline
Expected behaviour
New node does not have a animation applied to it
materialAnimationBug.blend
note that the issue goes away after saving/reloading (so in this step the borked animation paths seem to be cleaned up)
**System Information** Operating system: Ubuntu 21.04 Graphics card: GTX 1080 **Blender Version** Broken: 3.2.1 Worked: 2.79 **Short description of error** Animation on a node, that then gets put into a node group, effects other nodes later on **Exact steps for others to reproduce the error** 1. Open attached blend file 2. Make sure you have blender 2.79 hotkeys otherwise i dont know if this will work 100% 3. in the material editor, press ctrl g to add it to a node group 4. press tab to exit out 5. shift a -> c -> m (add mix node) 6. drop it between the node group and the hue sat value node 7. scrub the timeline Expected behaviour New node does not have a animation applied to it [materialAnimationBug.blend](https://archive.blender.org/developer/F13497413/materialAnimationBug.blend) note that the issue goes away after saving/reloading (so in this step the borked animation paths seem to be cleaned up)
Added subscriber: @candreacchio
Added subscriber: @iss
That's quite interesting, it actually affects the result, so it's not just UI glitch...
Yep, and whats more crazy is that the element thats animated, is not highlighted yellow / green
Member
Added subscriber: @lichtwerk
Member
There is something wrong in interpreting that FCurve path.
Since this is name-based, blender somewhat gets confused because of that "duplicate" name (both nodes are named "Mix.001" - only one is inside the nodegroup, the other one not...)
If the "failing" one is renamed, the issue goes away on it (it is still preserved on the "working" in the nodegroup.
On a side-note: Just realized that if a node has animation (such as the Factor here) and it gets grouped, the Factor is then noodled up to the nodegroup (which is generally a good thing -- issue being that the effective animation on the node is now disabled, since the Factor on the nodegroup itself is not getting the animation transferred over).
Will report that separately though.
There is something wrong in interpreting that FCurve path. Since this is name-based, blender somewhat gets confused because of that "duplicate" name (both nodes are named "Mix.001" - only one is inside the nodegroup, the other one not...) If the "failing" one is renamed, the issue goes away on it (it is still preserved on the "working" in the nodegroup. On a side-note: Just realized that if a node has animation (such as the `Factor` here) and it gets grouped, the `Factor` is then noodled up to the nodegroup (which is generally a good thing -- issue being that the effective animation on the node is now disabled, since the Factor on the nodegroup itself is not getting the animation transferred over). Will report that separately though.
Member
@candreacchio : is that what you meant with the following?
> In #101109#1418068, @lichtwerk wrote: > On a side-note: Just realized that if a node has animation (such as the `Factor` here) and it gets grouped, the `Factor` is then noodled up to the nodegroup (which is generally a good thing -- issue being that the effective animation on the node is now disabled, since the Factor on the nodegroup itself is not getting the animation transferred over). > Will report that separately though. @candreacchio : is that what you meant with the following? > In #101109#1418015, @candreacchio wrote: > Yep, and whats more crazy is that the element thats animated, is not highlighted yellow / green
Factor colour i was commenting on
2022-09-16 18-15-52.mkv
Following on from this, if you instead of adding in another mixrgb node, you rename the Hue Sat node to Mix.001, it will animate the Hue 0,1 and not the factor.
The animation gets unlinked if you save / revert the file. However, it is not an ideal workflow.
I have also had duplicated objects be effected similarly previously (where trying to make unique animation, doesnt actually make it unique animation) and the only way to fix it was to save close reopen, but unable to replicate it like this instance.
Factor colour i was commenting on [2022-09-16 18-15-52.mkv](https://archive.blender.org/developer/F13498817/2022-09-16_18-15-52.mkv) Following on from this, if you instead of adding in another mixrgb node, you rename the Hue Sat node to Mix.001, it will animate the Hue 0,1 and not the factor. The animation gets unlinked if you save / revert the file. However, it is not an ideal workflow. I have also had duplicated objects be effected similarly previously (where trying to make unique animation, doesnt actually make it unique animation) and the only way to fix it was to save close reopen, but unable to replicate it like this instance.
Member
Also note that the issue goes away after saving/reloading (so in this step the borked animation paths seem to be cleaned up)
Philipp Oeser changed title from Blender 3.2.1 - Animation on Material Nodes gets bugged out when dealing with Node Groups to Blender 3.2.1 - Animation on Material Nodes gets bugged out when dealing with Node Groups (duplicate node names) 2022-09-16 10:54:58 +02:00
Member
Same is true for Geometry nodes as well
Philipp Oeser changed title from Blender 3.2.1 - Animation on Material Nodes gets bugged out when dealing with Node Groups (duplicate node names) to Blender 3.2.1 - Animation on nodes gets bugged out when dealing with Node Groups (duplicate node names) 2022-09-16 10:57:29 +02:00
Philipp Oeser self-assigned this 2022-09-16 12:37:53 +02:00
Member
Think I got the fix
Think I got the fix
This issue was referenced by 1e7e1b151c
This issue was referenced by 1e7e1b151c469c2f20c7666ef9def499d2a71967
This issue was referenced by 740b501d8b
This issue was referenced by 740b501d8b6ebdb53a0bde79556760513f9492c6
This issue was referenced by eb54502d9d
This issue was referenced by eb54502d9d29b18cbeda22125a601f3ce0bc423e
Member
Reference: blender/blender#101109
