Geometry nodes: Instances Incorrectly Rendered with Motion Blur when deleting Instances. #101152
Reference: blender/blender#101152
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3080 Ti Laptop GPU/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash:
0759f671ce
Worked: None that I'm aware of. 3.4 alpha shows the same behavior
Motion Blur artifacts appear when deleting instances in both EEVEE and cycles
I suspect that deleting the instances causes indices shifts that tricks motion blur code to "think" that a particular instance moved. Motion blur from the old position to the new is rendered. But actually the instance didn't move, It's only the index that has changed.
This is pure speculation based on my intuition, I don't know how motion blur is actually implemented, so I may be wrong about the cause.
Realizing instances seems to "fix" the problem.
I Experienced the same glitch in a production file using the "scale elements" node, scaling some elements from zero to one and others viceversa, but currently I can't replicate the error. Real geometry, no instances this time. I had to scale from a very small scale instead of zero to work around it.
Render frame 10 of the attached file and the motion blur glitch will appear on the instanced geometry, but not on the realized instances. It's also present in other frames, but not all.
geometry_nodes_motion_blur_bug_v01.blend
Added subscriber: @RiccardoBancone
Cycles Incorrectly Rendered in Geometry Nodes when deleting Instances.to Cycles Incorrectly Rendered Motion Blur in Geometry Nodes when deleting Instances.Added subscriber: @mod_moder
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
It clearly doesn't look like it should. But there is a small chance that it was intended, just in case, I'll ask
@HooglyBoogly
Cycles Incorrectly Rendered Motion Blur in Geometry Nodes when deleting Instances.to Geometry nodes: Instances Incorrectly Rendered with Motion Blur when deleting Instances.Added subscriber: @JacquesLucke
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
The
id
attribute is used to map instances between different frames for motion blur. If the attribute does not exist, the index will be used instead. The solution here is to set the ids before starting to delete instances. Just adding aSet ID
node beforeDelete Geometry
fixes it.
