edit mode too slow when using selection tools in my model and an object with empty hair too slow when move and dragging in the viewport... #101202
2 Participants
Reference: blender/blender#101202
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.65
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash:
0759f671ce
1- after adding an Empty hair to an object causes the object to lag miserably slow when move and drag in the viewport...
2- while entering edit mode, a lag is noticeable, but it becomes worst when using lasso select and then select some random bigger or small portion of the mesh, it takes a few seconds to select anything in edit mode in this model provided, and when i unselect with A what i selected before with the lasso tool it seems to be no lag, and then the worst part that made me not use this version of blender for this project at the moment is that when i press A to select all in edit mode, blender freezes forever and causes my pc to be at 90-100 % of cpu usage for some stupid select all maneuver...
3- i checked doing the same issue from 1 with the default cube instead from my startup file, then i subdivided 15 times the cube in edit mode and i noticed a strange lag if the object has 3 or more levels additional of subdivision (but from subdiv modifier and gets about 100 k faces which is really nothing to lag like that), though without any empty hair attached to it, it moves and drags fast as usual...
fox-girl-body-1
fox-girl-body-1
fox-girl-1-1.blend
Added subscriber: @Michael-Colina
Added subscriber: @mano-wii
Either these steps aren't clear, or I can't reproduce the problem.
This report is not so clear so I understood the steps as:
fox-girl-body-1
Did I get it wrong?
Please give us more clear instructions on how to reproduce it.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Yes i said move and drag in the viewport without any axis contrainting, you know just pressing G alone you know 🙃...
Apparently what happens is that the
Deform Curve on Surface
node needs to run when the mesh moves.In fact, the lag is accentuated and worse than the previous hair system.
But I don't think this can be considered a bug. The new hair system is recent and performance improvements are still being worked on.
So I'm closing the report.
It can be reopened if approved by the developers.
Ok fair enough for the premature development of that at the moment, but what about the mesh in edit mode selection issue mentioned earlier? (btw sorry for adding both errors in one report, but i thought it made sense because happened in the same file so...)
This also triggers the recalculation of the modifiers. Hence the lag.
Oh sorry i meant, that issue happened without any empty hair added, also with/o modifiers added, so this other issue wasn't related to the hair actually...
That's what i described that in the default cube which i could select fast as usual but not in model made in the previous version of blender...
Maybe got corrupted perhaps after opening it in 3.3? Because in 3.2.1 i can select fast and lasso select normally
