Regression: Edited action in NLA ignored settings #101275
Closed
opened 2022-09-22 18:41:23 +02:00 by Alexander · 24 comments
Operating system: Ubuntu 20.04
Graphics card:
Broken: 3.4 alpha
Worked: 3.2
In 3.3: Influence works only when nla strip is selected. But panel is removed in 3.4 for active strip: {b6ebd5591c7f0e7037a2af66b5e1d96125834949}
Also- influence property doesn't update the base action contribution when only action is selected. Behavior changed in 61e8310b75
The action being edited ignores any settings in the NLA. It is quite possible that the problem is in the N panel itself, because in 3.3 the action reacted to changing the settings only in the "Edited Action" category
**System Information** Operating system: Ubuntu 20.04 Graphics card: **Blender Version** Broken: 3.4 alpha Worked: 3.2 In 3.3: Influence works only when nla strip is selected. But panel is removed in 3.4 for active strip: {b6ebd5591c7f0e7037a2af66b5e1d96125834949} Also- influence property doesn't update the base action contribution when only action is selected. Behavior changed in 61e8310b75 **Short description of error** The action being edited ignores any settings in the NLA. It is quite possible that the problem is in the N panel itself, because in 3.3 the action reacted to changing the settings only in the "Edited Action" category **Exact steps for others to reproduce the error** - Open .blend - Change influence slider [#101275.blend](https://archive.blender.org/developer/F13558590/T101275.blend) [2022-09-22 19-36-32.mp4](https://archive.blender.org/developer/F13555241/2022-09-22_19-36-32.mp4)
Author
Added subscriber: @sanek2005
Alexander changed title from Edited in NLA ignored settings to Edited action in NLA ignored settings 2022-09-22 18:42:04 +02:00
Member
Added subscriber: @BClark
Member
You don't have the action selected in the second part of the video where it isn't working, you have it selected in the first part where it is.
Author
@BClark no. either it just can't be selected, or I don't know something
2022-09-22 22-23-44.mp4
@BClark no. either it just can't be selected, or I don't know something [2022-09-22 22-23-44.mp4](https://archive.blender.org/developer/F13556071/2022-09-22_22-23-44.mp4)
Member
Member
Sorry, you are correct, it isn't impacting the top action blend, good find, Bug!
Member
Member
As far as I can see Edited action panel is missing for the selected strip. I'll check
As far as I can see `Edited action` panel is missing for the selected strip. I'll check
Member
The base action doesn't have a strip as it is just the action.. all of this part of the UI is still needing refinement but The influence should be working like it did in 3.3
Member
Panel was removed in b6ebd5591c which was done purposefully.
With no strip selected influence operation neither works in 3.3 but it does in 3.2
Raising the priority
Panel was removed in b6ebd5591c7f0e7037a2af66b5e1d96125834949 which was done purposefully. With no strip selected influence operation neither works in 3.3 but it does in 3.2 Raising the priority
Member
Hello Brad, for me influence property neither works in 3.3. Could you confirm in uploaded file?
#101275.blend
> In #101275#1421377, @BClark wrote: > The base action doesn't have a strip as it is just the action.. all of this part of the UI is still needing refinement but The influence should be working like it did in 3.3 Hello Brad, for me influence property neither works in 3.3. Could you confirm in uploaded file? [#101275.blend](https://archive.blender.org/developer/F13558590/T101275.blend)
Member
3.3 is working but sort of.
IF you accidentally click on a "strip" and the UI updates to show the Strip Info. then when you deselect it, the action no longer becomes active and the Edited Action settings no longer work.
So what I am seeing is if I create an action fresh and then try and adjust the settings it works. If I click away and select something else, the influence don't update /refresh the action but it does read it when you create a strip.
There is something not getting set back to active when you click on a strip and then deselect widh
3.3 is working but sort of. IF you accidentally click on a "strip" and the UI updates to show the Strip Info. then when you deselect it, the action no longer becomes active and the Edited Action settings no longer work. So what I am seeing is if I create an action fresh and then try and adjust the settings it works. If I click away and select something else, the influence don't update /refresh the action but it does read it when you create a strip. There is something not getting set back to active when you click on a strip and then deselect widh
Member
Added subscribers: @nrupsis, @dr.sybren
Member
Thanks, Few notes after testing multiple versions::
If NLA strip is selected from the stack then influence works. but now panel is removed for active strips in b6ebd5591c
If base action is selected in nla editor then I expect influence slider to update the viewport based on its value but it neither contributes since 61e8310b75
cc @nrupsis
cc @dr.sybren
Thanks, Few notes after testing multiple versions:: If NLA strip is selected from the stack then influence works. but now panel is removed for active strips in b6ebd5591c7f0e7037a2af66b5e1d96125834949 If base action is selected in nla editor then I expect `influence` slider to update the viewport based on its value but it neither contributes since 61e8310b75 cc @nrupsis cc @dr.sybren
Member
Yes, the panel is removed for active scripts because that "Edit Action panel" has nothing to do with the Selected Strips. It is only fro the Creation of and interaction with the Base action.
The issue is that somehow the base action is no longer being seen/getting updated once you deselect the strip and the UI shows the "Edited Action" tab again.
Yes, the panel is removed for active scripts because that "Edit Action panel" has nothing to do with the Selected Strips. It is only fro the Creation of and interaction with the Base action. The issue is that somehow the base action is no longer being seen/getting updated once you deselect the strip and the UI shows the "Edited Action" tab again.
Member
Ugh yeah. That's weird. My changes didn't necessarily cause it. But they are definitely preventing it.
Upon initial investigation, I didn't see anything that stuck out to me. I'll keep looking into it.
Do either of you know the distinction between a NLA-Track and an NLA-Strip ?
Ugh yeah. That's weird. My changes didn't necessarily cause it. But they are definitely preventing it. Upon initial investigation, I didn't see anything that stuck out to me. I'll keep looking into it. Do either of you know the distinction between a `NLA-Track` and an `NLA-Strip` ?
Member
Track should be where the Strip lives but I wonder if the scene action has a default track?
Pratik Borhade changed title from Edited action in NLA ignored settings to Regression: Edited action in NLA ignored settings 2022-09-27 06:15:52 +02:00
Member
Investigating this a little more, and it comes down to (afaik) a dependency issue. Or rather, data ownership.
A log from "now hidden" action panel's influence relieves that the dependency graph updates it's owners Id, i.e the cube:
graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, ANIMATION source=USER_EDIT
graph_id_tag_update: id=MECube flags=LEGACY_0 source=USER_EDIT
graph_id_tag_update: id=OBCube flags=COPY_ON_WRITE source=USER_EDIT
When acting upon the Action Strip ("scale-all") in this case, the action strip is the owner of that data block, thus the dependency graph is doing what it should, but since there isn't a dependency, nothing is happening:
graph_id_tag_update: id=ACscale-all flags=TRANSFORM, GEOMETRY, ANIMATION source=USER_EDIT
graph_id_tag_update: id=ACscale-all flags=COPY_ON_WRITE source=USER_EDIT
At this point, my lack of Animation Data is blocking me. I have a feeling I could figure out a way to connect the Action's data to the mesh it's acting upon, but It would be hackish.
@dr.sybren do you have any ideas?
Investigating this a little more, and it comes down to (afaik) a dependency issue. Or rather, data ownership. A log from "now hidden" action panel's influence relieves that the dependency graph updates it's owners Id, i.e the cube: ``` graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, ANIMATION source=USER_EDIT graph_id_tag_update: id=OBCube flags=TRANSFORM, GEOMETRY, ANIMATION source=USER_EDIT graph_id_tag_update: id=MECube flags=LEGACY_0 source=USER_EDIT graph_id_tag_update: id=OBCube flags=COPY_ON_WRITE source=USER_EDIT graph_id_tag_update: id=OBCube flags=COPY_ON_WRITE source=USER_EDIT ``` When acting upon the Action Strip ("scale-all") in this case, the action strip _is_ the owner of that data block, thus the dependency graph is doing what it should, but since there isn't a dependency, nothing is happening: ``` graph_id_tag_update: id=ACscale-all flags=TRANSFORM, GEOMETRY, ANIMATION source=USER_EDIT graph_id_tag_update: id=ACscale-all flags=TRANSFORM, GEOMETRY, ANIMATION source=USER_EDIT graph_id_tag_update: id=ACscale-all flags=COPY_ON_WRITE source=USER_EDIT graph_id_tag_update: id=ACscale-all flags=COPY_ON_WRITE source=USER_EDIT ``` At this point, my lack of Animation Data is blocking me. I have a feeling I _could_ figure out a way to connect the Action's data to the mesh it's acting upon, but It would be hackish. @dr.sybren do you have any ideas?
Member
hmm So shouldn't the ID in the first section but cube action? the id= the strip in the second set of code but the first ID isn't showing the action it is just showing the cube?
Member
My understanding is (and please correct me if I'm wrong) an action is a set of keyframes that exist as it's own "editable" datablock. I can assign an action to multiple objects, and when the action is edited (i.e, I move a frame) it's updated across all uses of that action.
A NLA strip is a "Packaged" Action, in the sense that it's completed. If I were to edit one NLA strip, it wouldn't affect the others.
So when it comes down to influence, an object "owns" the NLA strip, and thus when the influence is updated, the owner Id (I.e, the cube) is sent to the dependency graph to be updated, and the mesh object updates ("scales') in this instance.
However, when an action is updated, the action's Id is passed, since it's the owner of that data, and thus no mesh is updated.
I assume the reason for this, is that an action can be a one to many relationship, and thus we don't want to implicitly update a bunch of meshes for the user.
To answer the question "So shouldn't the ID in the first section but cube action?", from a user perspective, Yes, I would agree. But from a data ownership perspective, I'm not sure.
My understanding is (and please correct me if I'm wrong) an action is a set of keyframes that exist as it's own "editable" datablock. I can assign an action to multiple objects, and when the action is edited (i.e, I move a frame) it's updated across all uses of that action. A NLA strip is a "Packaged" Action, in the sense that it's completed. If I were to edit one NLA strip, it wouldn't affect the others. So when it comes down to influence, an object "owns" the NLA strip, and thus when the influence is updated, the owner Id (I.e, the cube) is sent to the dependency graph to be updated, and the mesh object updates ("scales') in this instance. However, when an action is updated, the action's Id is passed, since it's the owner of that data, and thus no mesh is updated. I assume the reason for this, is that an action can be a one to many relationship, and thus we don't want to implicitly update a bunch of meshes for the user. To answer the question "So shouldn't the ID in the first section but cube action?", from a user perspective, Yes, I would agree. But from a data ownership perspective, I'm not sure.
Member
This comment was removed by @BClark
*This comment was removed by @BClark*
This issue was referenced by bfc9d7cadf
This issue was referenced by bfc9d7cadfe834c477b1d7423304da3d962c9df3
This issue was referenced by f96b729d7b
This issue was referenced by f96b729d7b5a6406fab07108b1cbbbd07b635d51
Member
Nate Rupsis self-assigned this 2022-10-08 13:25:16 +02:00
Asset System
Code Documentation
FBX
Pipeline & IO
Viewport & EEVEE
glTF
Asset Browser Project
Asset System
Pipeline & IO
Viewport & EEVEE
Severity
Severity
Severity
Severity
5 Participants
Reference: blender/blender#101275
